cgal-discuss - Re: [cgal-discuss] valgring (alpha shapes) and cgal
  • To:
  • Subject: Re: [cgal-discuss] valgring (alpha shapes) and cgal
  • Date: Tue, 05 Oct 2010 16:07:26 +0200
  • Organization: INRIA
Le 05/10/10 16:00, Lukasz Kaczmarczyk a écrit :
Hello,
I like to use valgrind with cglal, however I get this error:
==12851== Memcheck, a memory error detector
==12851== Copyright (C) 2002-2010, and GNU GPL'd, by Julian Seward et al.
==12851== Using Valgrind-3.6.0.SVN and LibVEX; rerun with -h for copyright
info
==12851== Command: ./test_sens -ksp_type gmres -pc_type lu -snes_type ls
-snes_ls basic -snes_converged_reason -snes_monitor -snes_max_it 10 -ksp_rtol
1e-12 -ksp_atol 1e-12
==12851==
--12851-- ./test_sens:
--12851-- dSYM directory is missing; consider using --dsymutil=yes
--12851-- /Users/likask/MyBuild/droplet/build/libdroplet.dylib:
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: -CGAL_IA_MUL(-1.1, 10.1) != CGAL_IA_MUL(1.1, 10.1)
File: /opt/local/include/CGAL/Interval_nt.h
Line: 158
I check my code for two kernels,
//typedef CGAL::Exact_predicates_inexact_constructions_kernel K_;
typedef CGAL::Simple_cartesian<double> K_;
I use alpha shapes, there is a solution for this problem?
The thread at http://goo.gl/CuZw might help (or not).
Sylvain
