cgal-discuss - Re: [cgal-discuss] Location of "thin" map faces
  • To:
  • Subject: Re: [cgal-discuss] Location of "thin" map faces
  • Date: Tue, 05 Oct 2010 10:57:59 -0400
Hi Efi,
Yes it does. It may not be what you are looking for, but this is what is called the (directional) width of a point set in comp. geometry.
Thanks. The actual length I am interested in is the smallest length 'r' such that: insetting the polygon by a disc of radius 'r' yields the empty set (E.g. the inset collapses the polygon to nothing).
I'm not sure if this has a name...it is potentially a lot thinner than the polygon width (or directional width).
In particular, I can verify whether a polygon is, um, "narrower" (I don't want to use width since that clearly has a real mathematical meaning) by performing the inset, but it would be useful to know the actual value of R.
cheers
Ben
