- To:
- Subject: [cgal-discuss] CGAL:: accessing vertices of segment Delaunay graph?
- Date: Tue, 12 Oct 2010 10:52:56 -0700 (PDT)
Hello,
I'm stuck with trying to get vertices of segment Delaunay graph. I was
trying to iterate through the non-infinite edges of the segment
Delaunay graph as in the sample in CGAL, trying this inside the loop:
SDG2::Edge e = *eit;
cout<<*( e.first->vertex( sdg.ccw(e.second) ));
cout<<*( e.first->vertex( sdg.cw(e.second) ));
The code gives nothing as result, only segments that points belong to
are written if I also use ->site() method. But I'm interested in
endpoints of edges ...
I get similar result using Finite_vertices_iterator.
Did anyone try to get these vertices? Please, I would be very grateful
for help...
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-accessing-vertices-of-segment-Delaunay-graph-tp2992409p2992409.html
- [cgal-discuss] CGAL:: accessing vertices of segment Delaunay graph?, annie, 10/12/2010
- Re: [cgal-discuss] CGAL:: accessing vertices of segment Delaunay graph?, Sebastien Loriot (GeometryFactory), 10/13/2010
- [cgal-discuss] Re: CGAL:: accessing vertices of segment Delaunay graph?, annie, 10/14/2010
- [cgal-discuss] Re: CGAL:: accessing vertices of segment Delaunay graph?, annie, 10/18/2010
