cgal-discuss - Re: [cgal-discuss] Classification problem in 2D Alpha Shapes
  • To:
  • Subject: Re: [cgal-discuss] Classification problem in 2D Alpha Shapes
  • Date: Mon, 11 Oct 2010 13:29:44 +0200
Benoît Presles wrote:
Hello everybody,
I did a program which first computes the alpha shape (GENERAL mode) of some points for a specific alpha value and then classifies the points and the edges of the underlying Delaunay triangulation. The problem is that I do not understand the results I get.
First program:
- I compute the alpha shape (GENERAL mode, alpha value = *(A.alpha_begin())) of some points (cf. "fin.txt") and I classify the points and the edges of the underlying Delaunay triangulation (cf. Delaunay.png).
Output:
Reading 10 points from file
Alpha Shape computed
1 alpha shape edges
--OUT--
0.848177 0.590931 0.884446 0.641268
EIRS 0 0 0 10
EIRS 20 0 0 1
So I get only 1 edge: 20 edges are "exterior", 1 is singular (cf. alphaShapeSegments_1.png).
I agree with this result but I do not understand why I get 10 singular points (EIRS 0 0 0 10).
see below
Second program:
- I compute the alpha shape (GENERAL mode, alpha value = *(A.alpha_begin()+9)) of some points (cf. "fin.txt") and I classify the points and the edges of the underlying Delaunay triangulation (cf. Delaunay.png).
Output:
10 alpha shape edges
--OUT--
0.884446 0.641268 0.727141 0.658053
0.604772 0.345775 0.69997 0.404789
0.727141 0.658053 0.848177 0.590931
0.560009 0.78025 0.407242 0.774075
0.324098 0.0413514 0.484923 0.0451195
0.188165 0.171543 0.324098 0.0413514
0.727141 0.658053 0.560009 0.78025
0.69997 0.404789 0.848177 0.590931
0.727141 0.658053 0.69997 0.404789
EIRS 0 0 3 7
EIRS 11 0 3 7
In this case, I do not understand both results: "EIRS 0 0 3 7" and "EIRS 11 0 3 7" (cf. alphaShapeSegments_2.png).
If you look at the classification of faces, you will see that only one face is in the alpha complex, thus only three edges are regular.
Considering the classification of vertices, as documented here:
http://www.cgal.org/Manual/beta/doc_html/cgal_manual/Alpha_shapes_2/Chapter_main.html#Section_40.2
"... singular/regular, that is be on the boundary of the alpha-shape, but not incident/incident to a triangle of the alpha-complex"
That is, a vertex stops being singular as soon as an incident face belongs to the alpha-complex.
This is not the definition you can find in the paper
of Edelsbrunner and Muecke and I understand this is misleading.
If you need this definition for the classification of the vertices, you can try uncommenting part of code in the function initialize_interval_vertex_map
(below
//-------------- examine incident edges --------------------------
Thank you very much for your help,
Best Regards,
Benoît
