cgal-discuss - Re: [cgal-discuss] Vertice flexibility in segment Delaunay 2d
  • To:
  • Subject: Re: [cgal-discuss] Vertice flexibility in segment Delaunay 2d
  • Date: Tue, 19 Oct 2010 13:42:55 +0200
annie wrote:
Hello,
I'm trying to get geometric coordinates of vertices of segment Delaunay
graph.
How to plug in the proper class for vertices there?
There is a class TriangulationDataStructure_2::Vertex with a member point(),
which is used in point Delaunay graph. With segment,
Segment_Delaunay_graph_vertex_base_2 class doesn't have one. There is also
some rebind mechanism there. Is it possible to use class with point() for
vertices in segment Delaunay graph? Of course I wish this method would
return proper coordinates.
I would be very grateful for any help as I'm trying hard to get vertices
from a while...
annie
The following is working for me:
SDG2::Finite_vertices_iterator it=sdg.finite_vertices_begin();
for (;it!=sdg.finite_vertices_end();++it){
if (it->site().is_point())
std::cout << it->site().point() << std::endl;
if (it->site().is_segment())
std::cout << it->site().segment() << std::endl;
The documentation is here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Segment_Delaunay_graph_2_ref/Concept_SegmentDelaunayGraphSite_2.html
If you need the exact constructions, you probably need to use the storage site documented here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Segment_Delaunay_graph_2_ref/Concept_SegmentDelaunayGraphStorageSite_2.html
The representation of output sites is given here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Segment_Delaunay_graph_2/Chapter_main.html#Section_42.2
S.
