cgal-discuss - Re: [cgal-discuss] Re: Vertice flexibility in segment Delaunay 2d
  • To:
  • Subject: Re: [cgal-discuss] Re: Vertice flexibility in segment Delaunay 2d
  • Date: Tue, 19 Oct 2010 14:58:54 +0200
annie wrote:
Thank you for response.
If I am correct, your code gives me only sites (points or segments), not
proper points of Delaunay triangulation graph. I will give a short example -
according to http://www.lmia.uha.fr/~mage/brevilliers/2008_ewcg_slides.pdf
on the slide 3 I see two points on segment S2 which belong to
triangulations. They're not endpoints of segment or points of Voronoi
diagram.
OK, from what I understand, the points you are looking for
does not exists (a unique embedding can not be given).
The triangulation is simply a graph so only the topology is encoded by
the data structure in CGAL.
If you do need a point, you can take one on the segment (but it may not
be well suited for your application).
S.
I have already read documentation, but still I'm confused how to get what I
need.
Your help is inestimable for me;)
annie
