cgal-discuss - Re: [cgal-discuss] triangulate a half sphere
  • To:
  • Subject: Re: [cgal-discuss] triangulate a half sphere
  • Date: Wed, 20 Oct 2010 16:48:00 +0200
Rolf Wester wrote:
Hi,
I'm totally new to CGAL and as CGAL is quite a big library I'm a little bit lost
in the CGAL universe.
Welcome Rolf,
I would like to triangulate a half sphere and get the vertices and cells. I modified the
triangulating a sphere example:
FT sphere_function (Point_3 p) {
const FT x2=p.x()*p.x(), y2=p.y()*p.y(), z2=p.z()*p.z();
if(z2 < 0.0) return 0.0; // added this line
return x2+y2+z2-1;
I guess this is not the best way to do it. Besides this I couldn't find a way to get the vertices
and cells. Is there a documentation of all the classes and their respective methods?
you can use iterators provided by the complex_2_in_triangulation_3
documented here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Surface_mesher_ref/Concept_SurfaceMeshComplex_2InTriangulation_3.html
c2t3.facets_begin(),c2t3.facets_end()
c2t3.vertices_begin(),c2t3.vertices_end()
Be aware of the fact that a facet is a pair<Cell_handle,int> where the
integer is the index (0 -> 3) of the vertex opposite to the facet.
documentation is here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/TriangulationDS_3_ref/Concept_TriangulationDataStructure_3.html#Cross_link_anchor_1338
S.
I would be very appreciative for your help.
Regards
Rolf
