- To:
- Subject: Re: [cgal-discuss] triangulate a half sphere
- Date: Wed, 20 Oct 2010 17:12:19 +0200
Le mercredi 20 octobre 2010 16:39:30, Rolf Wester a écrit :
> Hi,
> I'm totally new to CGAL and as CGAL is quite a big library I'm a little bit
> lost in the CGAL universe.
> I would like to triangulate a half sphere and get the vertices and cells. I
> modified the triangulating a sphere example:
> FT sphere_function (Point_3 p) {
> const FT x2=p.x()*p.x(), y2=p.y()*p.y(), z2=p.z()*p.z();
> if(z2 < 0.0) return 0.0; // added this line
> return x2+y2+z2-1;
z2 cannot be <0, because it is the square of a number. What is more, you must
return a stritcly positive number for the outside of your object. I suggest:
if(p.z() < 0) return 1.;
And the mesh methods in CGAL-3.7 are only for smooth objects. The mesh will
not be very acurate around the big circle x^2+y^2=0, z=0.
Laurent Rineau, PhD
- [cgal-discuss] triangulate a half sphere, Rolf Wester, 10/20/2010
- Re: [cgal-discuss] triangulate a half sphere, Sebastien Loriot (GeometryFactory), 10/20/2010
- Re: [cgal-discuss] triangulate a half sphere, Laurent Rineau (GeometryFactory), 10/20/2010
