- To:
- Subject: [cgal-discuss] Problems installing CGAL 3.7 on Mac OSX
- Date: Fri, 22 Oct 2010 12:38:33 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=from:content-type:subject:date:message-id:to:mime-version:x-mailer; b=DvKt7uWiNmMhCJX+lQMEFamtkqTkJAaf/e8DKhgtJNANk0Pyicm7ZCruImhmlav3Lr hoYBLlCC+S7nVUXA6omh5OctqwzQN9IPCdpGE/0XAl2gj99lGYob6e1KFqwSvIvILkcN O0r5DgjRN7vlVnwJMeegn1UP/zEIfJ5hljCsY=
Hi everyone, I am trying to install CGAL 3.7 on Snow Leopard. I have the current version of XCode installed, which means that I have a working gcc compiler in my /usr/bin directory. The gcc compiler is working properly as I tried compiling some test codes along with it. But I am unable to compile the CGAL with cmake because it gives the following errors -- The C compiler identification is GNU -- The CXX compiler identification is GNU -- Checking whether C compiler has -isysroot -- Checking whether C compiler has -isysroot - yes -- Checking whether C compiler supports OSX deployment target flag -- Checking whether C compiler supports OSX deployment target flag - yes -- Check for working C compiler: /usr/bin/gcc CMake Error: Generator: execution of make failed. Make command was: /opt/local/bin/gmake "cmTryCompileExec/fast" -- Check for working C compiler: /usr/bin/gcc -- broken CMake Error at /Applications/CMake 2.8-2.app/Contents/share/cmake-2.8/Modules/CMakeTestCCompiler.cmake:52 (MESSAGE): The C compiler "/usr/bin/gcc" is not able to compile a simple test program. It fails with the following output: Change Dir: /Users/write2vikash/Documents/CGAL-3.7/CMakeFiles/CMakeTmp Run Build Command:/opt/local/bin/gmake "cmTryCompileExec/fast" No such file or directory Generator: execution of make failed. Make command was: /opt/local/bin/gmake "cmTryCompileExec/fast" CMake will not be able to correctly generate this project. Call Stack (most recent call first): CMakeLists.txt:6 (project) -- Configuring incomplete, errors occurred! Any help will be greatly appreciated.. Thanks Vikash --- Vikash Gupta Graduate Student, Robotics and Autonomous Systems Laboratory Vanderbilt University. Web:http://people.vanderbilt.edu/~vikash.gupta Blog:http://gvikash.blogspot.com/ ---
Vikash Gupta Graduate Student, Robotics and Autonomous Systems Laboratory Vanderbilt University. Web:http://people.vanderbilt.edu/~vikash.gupta Blog:http://gvikash.blogspot.com/ |
- [cgal-discuss] Problems installing CGAL 3.7 on Mac OSX, Vikash Gupta, 10/22/2010
