cgal-discuss - Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?
  • To:
  • Subject: Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?
  • Date: Fri, 22 Oct 2010 13:12:08 +0200
Sebastian Kapfer wrote:
Hallo!
I was able to reproduce that on one of my machines, with your last code+data, with -O1, but not with -O0. It is probably a compiler bug. I do not understand it well.
Weird. I tried with GCC 4.4.3 which is the latest version I can get
my hands at without compiling GCC from source. It's still buggy.
I also tried Intel C++ a minute ago:
$ icpc --version
icpc (ICC) 11.0 20090609
Copyright (C) 1985-2009 Intel Corporation. All rights reserved.
Same message, aborts in line 267, even with -O0 and -fp-model strict.
Hm. :-(
The problem is due to floating point rounding.
Depending of the optimization done by the compiler an expression
was not evaluated the same way.
For convenience, I made a fix which solve the "problem" on my machine (patch file attached).
Also have a look at this FAQ entry:
http://www.cgal.org/FAQ.html#inexact_NT
S.
// Copyright (c) 2002 Utrecht University (The Netherlands).
// All rights reserved.
// This file is part of CGAL (www.cgal.org); you may redistribute it under
// the terms of the Q Public License version 1.0.
// See the file LICENSE.QPL distributed with CGAL.
// Licensees holding a valid commercial license may use this file in
// accordance with the commercial license agreement provided with the software.
// This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE
// WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
// $URL: svn+ssh://scm.gforge.inria.fr/svn/cgal/branches/CGAL-3.7-branch/Spatial_searching/include/CGAL/Euclidean_distance.h $
// $Id: Euclidean_distance.h 37183 2007-03-17 09:21:06Z afabri $
// Author(s)     : Hans Tangelder (<>)
#ifndef CGAL_EUCLIDEAN_DISTANCE_H
#define CGAL_EUCLIDEAN_DISTANCE_H
#include <CGAL/Kd_tree_rectangle.h>
namespace CGAL {
  template <class SearchTraits>
  class Euclidean_distance {
    public:
    typedef typename SearchTraits::FT    FT;
    typedef typename SearchTraits::Point_d Point_d;
    typedef Point_d Query_item;
    public:
    	// default constructor
    	Euclidean_distance() {}
	inline FT transformed_distance(const Query_item& q, const Point_d& p) const {
	        FT distance = FT(0);
		typename SearchTraits::Construct_cartesian_const_iterator_d construct_it;
                typename SearchTraits::Cartesian_const_iterator_d qit = construct_it(q),
		  qe = construct_it(q,1), pit = construct_it(p);
		for(; qit != qe; qit++, pit++){
		  distance += ((*qit)-(*pit))*((*qit)-(*pit));
        	return distance;
	inline FT min_distance_to_rectangle(const Query_item& q,
					    const Kd_tree_rectangle<SearchTraits>& r) const {
		  qe = construct_it(q,1);
		for(unsigned int i = 0;qit != qe; i++, qit++){
		  if((*qit) < r.min_coord(i))
				distance +=
				(r.min_coord(i)-(*qit))*(r.min_coord(i)-(*qit));
		  else if ((*qit) > r.max_coord(i))
				distance +=
				((*qit)-r.max_coord(i))*((*qit)-r.max_coord(i));
		return distance;
	inline FT max_distance_to_rectangle(const Query_item& q,
		FT distance=FT(0);
				if ((*qit) <= (r.min_coord(i)+r.max_coord(i))/FT(2.0))
					distance += (r.max_coord(i)-(*qit))*(r.max_coord(i)-(*qit));
				else
					distance += ((*qit)-r.min_coord(i))*((*qit)-r.min_coord(i));
		return distance;
	inline FT new_distance(FT dist, FT old_off, FT new_off,
			       int /* cutting_dimension */)  const {
		FT new_dist = dist + (new_off*new_off - old_off*old_off);
                return new_dist;
  inline FT transformed_distance(FT d) const {
		return d*d;
  inline FT inverse_of_transformed_distance(FT d) const {
		return CGAL::sqrt(d);
  }; // class Euclidean_distance
} // namespace CGAL
#endif // EUCLIDEAN_DISTANCE_H
