- To:
- Subject: [cgal-discuss] making mesh from image causes shrinkage
- Date: Tue, 26 Oct 2010 15:26:01 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:date:x-google-sender-auth:message-id:subject :from:to:content-type; b=Bv4fMMSt2A4JsoFpp8KMRo0CwH6moyJGTbXoWWpE9CrTk/YnBJ47azEMj6zz9iTLeh ErhpPswUCPogEt1l9ESUrdvbcx+QZumeqJt/4ViZmtY5MHeIwsroE/2QrEMYPUPd2uRt pSKRMKgDNPt9AvWA54uqKzPOzJzIa4HsubfzY=
Hi,
I have noticed a slight but systematic volume loss when meshing an
image with make_mesh_3. This is similar to the well known effect of
surface shrinking when smoothing a surface mesh. I was wondering if it
is possible to minimize / compensate for this effect using some
additional options to the mesher. Any hints are highly appreciated.
Regards,
Dominik
- [cgal-discuss] making mesh from image causes shrinkage, Dominik Szczerba, 10/26/2010
- <Possible follow-up(s)>
- Re: [cgal-discuss] making mesh from image causes shrinkage, Mariette Yvinec, 10/27/2010
- Re: [cgal-discuss] making mesh from image causes shrinkage, Dominik Szczerba, 10/27/2010
