cgal-discuss - Re: [cgal-discuss] making mesh from image causes shrinkage
  • To:
  • Subject: Re: [cgal-discuss] making mesh from image causes shrinkage
  • Date: Wed, 27 Oct 2010 14:26:21 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type :content-transfer-encoding; b=wLAF7+3p/oPtnZLe+EzAjL9W8ZE6ykrMV1kKQZsbdkdmuCUGwE/c3OILkKb3IgB6uh Mi3ipRYShcV+qpq8eN+td5uNpQpgVaF6r8AeiR/rAieEfrZGuTaZEy9GvjT1hXwevbgw tK3CtzzOxIInIAJNEx7UY9E3i9jUjrUJ4WYpI=
I am not modifying anything, just using the mesh_3D_image example in a
loop (changing representations image-tetmesh). I would appreciate
hints how to adopt the procedure.
I observe shrinkage in INTERNAL domains, i.e., not on the surface. Are
the internal boundaries also projected?
Best regards,
Dominik
On Wed, Oct 27, 2010 at 10:55 AM, Mariette Yvinec
wrote:
> This seems strange because vertices on boundary surfaces
> are projected back on surfaces when they are moved by
> the optimization processes.
> Did you try to modify the applied optimization processes
> or even disable some of them in turn, to see which one
> produces the shrinkage ?
> Dominik Szczerba wrote:
>> Hi,
>> I have noticed a slight but systematic volume loss when meshing an
>> image with make_mesh_3. This is similar to the well known effect of
>> surface shrinking when smoothing a surface mesh. I was wondering if it
>> is possible to minimize / compensate for this effect using some
>> additional options to the mesher. Any hints are highly appreciated.
>> Regards,
>> Dominik
> Mariette Yvinec
> Geometrica project team
> INRIA  Sophia-Antipolis
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
