Re: [cgal-discuss] Polyhedron/Nef interface example does not produce correct result.
- To:
- Subject: Re: [cgal-discuss] Polyhedron/Nef interface example does not produce correct result.
- Date: Thu, 28 Oct 2010 09:41:02 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:user-agent:mime-version:to:subject:references :in-reply-to:content-type:content-transfer-encoding; b=GkkRCdaLgrFPOpso8l94RO+O5vbGRZOpdUrGoxHiWfX51wvZV0EF6vTdButaa5J+KI 3o2qgzBWJyrgygqo4JT6BCf3Ywizq0yGzZ7ccWJHqzFez8JLoZbkAirscTmSqtAkNvOd 2wv96q0aqEaEGul/aE0Exwq3g46DpVEKt9VCM=
listboss wrote:
Thanks for your help Sebastien,I guess you need for any pair of facets sharing an edge that
1) in this line
0.0 10.0.0 0.0
10.0.0 is not a correct value
This happened when I pasted the code to email. The file on my machine
is alright.
2)orientation of faces is not consistent.
In CGAL, how do you make orientation of Polyhedron_3 consistent
(assuming it is orientable) ?
the common edge is oriented in opposite way in each facet.
ex: I consider 4 points, with points 1 and 2 shared.
a correct orientation is:
0 1 2
3 2 1
You can also use this convention:
*for a close surface: facet seen from outside the object are counterclockwise oriented
*for an open surface: choose one "side" and facets counterclockwise.
Note that the Polyhedron demo of CGAL provide a plugin that try to reorient a triangle soup.
The plugin inside-outside inverse all orientation of facets.
S.
I was not clear, the assertion is already in the CGAL code.
For the second problem reported, if you enable assert check in CGAL,
you would have get this error message:
What is the test that I should be sending to CGAL_assertion() ?
You probably compile CGAL in release mode where all
assertions are disable. If CGAL was compile in debug mode you would
have assertion enable.
See here:
http://www.cgal.org/Manual/latest/doc_html/installation_manual/Chapter_installation_manual.html#Subsection_4.7
how to build the lib in debug and release modes. Then setting correctly
CGAL_DIR will do the job.
Thanks again
- [cgal-discuss] Polyhedron/Nef interface example does not produce correct result., Hamid G, 10/27/2010
- Re: [cgal-discuss] Polyhedron/Nef interface example does not produce correct result., Sebastien Loriot (GeometryFactory), 10/27/2010
- Re: [cgal-discuss] Polyhedron/Nef interface example does not produce correct result., listboss, 10/27/2010
- Re: [cgal-discuss] Polyhedron/Nef interface example does not produce correct result., Sebastien Loriot (GeometryFactory), 10/28/2010
- [cgal-discuss] Re: Polyhedron/Nef interface example does not produce correct result., Hamid G, 10/29/2010
