[cgal-discuss] Polyhedron/Nef interface example does not produce correct result.
- To:
- Subject: [cgal-discuss] Polyhedron/Nef interface example does not produce correct result.
- Date: Tue, 26 Oct 2010 15:31:07 -0700 (PDT)
Hello
I just compiled/installed CGLA 3.7 on a 32-bit Debian linux box (gcc 4.4.5).
and I am trying to run the example code in
'example/Nef_3/interface_polyhedron.cpp'
I passed down the following OFF file and expected to get some proper result
but this is what I got:
$ ./interface_polyhedron < tet.off
OFF
0 0 0
Also using provided OFF file in example directory, gives:
$ ./interface_polyhedron < handling_double_coordinates.cin
Error !!!!!!!!!!!!!!!!!!!!!!!
Segmentation fault
I compiled the examples as instructed:
$ cmake -DCGAL_DIR=/path/to/cgal .
$ make
Any help is appreciated.
thanks in advance,
Hamid G
# tet.off
OFF
4 4 0
0.0 0.0 0.0
10.0 0.0 0.0
0.0 10.0.0 0.0
0.0 0.0 10.0
3 0 1 3
3 3 0 2
3 3 2 1
3 0 2 1
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Polyhedron-Nef-interface-example-does-not-produce-correct-result-tp3014608p3014608.html
- [cgal-discuss] Polyhedron/Nef interface example does not produce correct result., Hamid G, 10/27/2010
- Re: [cgal-discuss] Polyhedron/Nef interface example does not produce correct result., Sebastien Loriot (GeometryFactory), 10/27/2010
- Re: [cgal-discuss] Polyhedron/Nef interface example does not produce correct result., listboss, 10/27/2010
- Re: [cgal-discuss] Polyhedron/Nef interface example does not produce correct result., Sebastien Loriot (GeometryFactory), 10/28/2010
- [cgal-discuss] Re: Polyhedron/Nef interface example does not produce correct result., Hamid G, 10/29/2010
