- To:
- Subject: [cgal-discuss] Installation of CGAL-ipelets error on MAC OSX
- Date: Sat, 30 Oct 2010 05:24:37 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=from:content-type:subject:date:message-id:to:mime-version:x-mailer; b=xIktzppYB9H+BsneqWXgT3sQLjKQz4TGX6yFvnUXkDKDq4Ih7m6rgeN0CHB3oD9ntO t8duYtRE5bOkfJdTZwzJm3i2+7jXevk66utajSoZgN668lV0qLZ9WXhGu/D4zLmvG1uP fsFCU0aYPAoaJkO9R1Nby4zDfo9UYnw4BdLHU=
Hello everyone, I am having trouble installing CGAL-ipelets-0.9, which is available at I am doing the step by step procedure mentioned for the installation of CGAL-ipelets. Here is what I did. 1.I changed the IPELETDIR in config.pri to the preset working directory where I have ipelets. IPELETDIR=/Users/write2vikash/Documents/CGAL-3.7/CGAL-ipelets-0.9 2. setting environment variable I used the command export CGAL_MAKEFILE=/Users/write2vikash/Documents/CGAL-3.7/CGAL-ipelets-0.9/CGAL.pri.mk (I am not sure about this step though). 3. I do "make -f CGAL.pri.mk" I get the following output echo INCLUDEPATH += > CGAL.pri echo INCLUDEPATH += >> CGAL.pri echo LIBS += | sed -e 's/-lqt-mt//; s/-lCGALQt//;' >> CGAL.pri 3. I do "qmake" 4. now when I do make. I get the following error. make: *** No targets specified and no makefile found. Stop. If anyone can suggest me what I am doing wrong. It will be great. Thanks in advance Vikash ---
Vikash Gupta Graduate Student, Robotics and Autonomous Systems Laboratory Vanderbilt University. Web:http://people.vanderbilt.edu/~vikash.gupta Blog:http://gvikash.blogspot.com/ |
- [cgal-discuss] Installation of CGAL-ipelets error on MAC OSX, Vikash Gupta, 10/30/2010
