cgal-discuss - [cgal-discuss] Problems compiling CGAL examples on MAC OS X
  • To:
  • Subject: [cgal-discuss] Problems compiling CGAL examples on MAC OS X
  • Date: Sat, 30 Oct 2010 02:22:47 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=from:content-type:subject:date:message-id:to:mime-version:x-mailer; b=WRiXDphP9LhTfPuTA+2uBAyy6GSvHNXWWRcCZCEtiBQtX2i39p0Xn2s/juShOseebN trsgKrmYvzBkYSmBdEP+M54EzZFhqMRQZr8ndwZ9YGGsOFeVrx5cGKrGqpZo1159nI6m UT7dzrmcV6ywXc01C00Du5X9/+4mgRuszBrg0=
Hello Everyone,
I was successfully able to install CGAL 3.7 on MAC Snow Leopard. But when I try to compile the examples.. It gives me the following error:
Scanning dependencies of target stl_regular_field
[ 50%] Building CXX object CMakeFiles/stl_regular_field.dir/stl_regular_field.o
Linking CXX executable stl_regular_field
ld: warning: duplicate dylib /opt/local/lib/libboost_thread-mt.dylib
Undefined symbols:
  "___gmpq_add", referenced from:
      CGAL::Same_uncertainty_nt<CGAL::Sign, CGAL::Gmpq>::type CGAL::side_of_oriented_circleC2<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)in stl_regular_field.o
  "___gmpq_mul", referenced from:
      boost::operator*(CGAL::Gmpq const&, CGAL::Gmpq const&)in stl_regular_field.o
      CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Orientation_2<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Orientation_2<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_ref_count<double, CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_ref_count<double, CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> >, CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> >, CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> > >(CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> > const&, CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> > const&, CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> > const&) constin stl_regular_field.o
  "___gmpq_equal", referenced from:
      bool CGAL::Filtered_predicate<CGAL::CommonKernelFunctors::Equal_2<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CommonKernelFunctors::Equal_2<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_ref_count<double, CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_ref_count<double, CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> >, CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> > >(CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> > const&, CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> > const&) constin stl_regular_field.o
  "___gmpq_cmp", referenced from:
      CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Compare_x_2<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Compare_x_2<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_ref_count<double, CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_ref_count<double, CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> >, CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> > >(CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> > const&, CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> > const&) constin stl_regular_field.o
      CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Compare_y_2<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Compare_y_2<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_ref_count<double, CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_ref_count<double, CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> >, CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> > >(CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> > const&, CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> > const&) constin stl_regular_field.o
  "___gmpq_clear", referenced from:
      CGAL::Handle_for<CGAL::Gmpq_rep, std::allocator<CGAL::Gmpq_rep> >::~Handle_for()in stl_regular_field.o
      boost::operator-(CGAL::Gmpq const&, CGAL::Gmpq const&)in stl_regular_field.o
      CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_ref_count<double, CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >::operator()(CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> > const&) constin stl_regular_field.o
      CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Side_of_oriented_circle_2<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Side_of_oriented_circle_2<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_ref_count<double, CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_ref_count<double, CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> >, CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> >, CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> >, CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> > >(CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> > const&, CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> > const&, CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> > const&, CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Cartesian<double>, true> > const&) constin stl_regular_field.o
  "___gmpq_sub", referenced from:
  "___gmpq_init", referenced from:
  "___gmpq_set_d", referenced from:
ld: symbol(s) not found
collect2: ld returned 1 exit status
make[2]: *** [stl_regular_field] Error 1
make[1]: *** [CMakeFiles/stl_regular_field.dir/all] Error 2
make: *** [all] Error 2
Since the error is huge I think it is something fundamental... I am able to use cmake . But when I do make, the above error is generated..
ANy help will be really appreciated. I am trying to work it out for last 2 weeks.
Sincerely
Vikash
Vikash Gupta
Graduate Student,
Robotics and Autonomous Systems Laboratory
Vanderbilt University.
Web:http://people.vanderbilt.edu/~vikash.gupta
Blog:http://gvikash.blogspot.com/
  • [cgal-discuss] Problems compiling CGAL examples on MAC OS X, Vikash Gupta, 10/30/2010
