cgal-discuss - [cgal-discuss] intel compiler
  • To:
  • Subject: [cgal-discuss] intel compiler
  • Date: Thu, 2 Dec 2010 11:42:57 +0000
Hello,
I try to compile CGAL with intel compiler on linux, however I gat error
CMakeFiles/cmTryCompileExec.dir/testCXXCompiler.cxx.o:(.eh_frame+0x12):
undefined reference to `__gxx_personality_v0'
Can you recommend me something. I have large number of libraries compiled
with intel, I will like to avoid to recompile everything for gcc.
Thanks for help,
Kind Regards,
Lukasz
cmake -DCMAKE_INSTALL_PREFIX=/home/civil/lukasz/MyBuild/local
-DCMAKE_CXX_COMPILER=icc -DCMAKE_C_COMPILER=icc ../
-- The C compiler identification is Intel
-- The CXX compiler identification is Intel
-- Check for working C compiler:
/storage/cm/shared/apps/intel/Compiler/11.1/046/bin/intel64/icc
/storage/cm/shared/apps/intel/Compiler/11.1/046/bin/intel64/icc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler:
/storage/cm/shared/apps/intel/Compiler/11.1/046/bin/intel64/icc -- broken
CMake Error at
/home/civil/lukasz/MyBuild/local/share/cmake-2.6/Modules/CMakeTestCXXCompiler.cmake:25
(MESSAGE):
The C++ compiler
"/storage/cm/shared/apps/intel/Compiler/11.1/046/bin/intel64/icc" is not
able to compile a simple test program.
It fails with the following output:
Change Dir: /home/civil/lukasz/MyBuild/CGAL-3.7/build/CMakeFiles/CMakeTmp
Run Build Command:/usr/bin/gmake "cmTryCompileExec/fast"
/usr/bin/gmake -f CMakeFiles/cmTryCompileExec.dir/build.make
gmake[1]: Entering directory
`/storage/home/civil/lukasz/MyBuild/CGAL-3.7/build/CMakeFiles/CMakeTmp'
/home/civil/lukasz/MyBuild/local/bin/cmake -E cmake_progress_report
/home/civil/lukasz/MyBuild/CGAL-3.7/build/CMakeFiles/CMakeTmp/CMakeFiles 1
Building CXX object CMakeFiles/cmTryCompileExec.dir/testCXXCompiler.cxx.o
/storage/cm/shared/apps/intel/Compiler/11.1/046/bin/intel64/icc -o
CMakeFiles/cmTryCompileExec.dir/testCXXCompiler.cxx.o -c
/home/civil/lukasz/MyBuild/CGAL-3.7/build/CMakeFiles/CMakeTmp/testCXXCompiler.cxx
Linking CXX executable cmTryCompileExec
/home/civil/lukasz/MyBuild/local/bin/cmake -E cmake_link_script
CMakeFiles/cmTryCompileExec.dir/link.txt --verbose=1
/storage/cm/shared/apps/intel/Compiler/11.1/046/bin/intel64/icc -fPIC
CMakeFiles/cmTryCompileExec.dir/testCXXCompiler.cxx.o -o cmTryCompileExec
-rdynamic
gmake[1]: Leaving directory
gmake[1]: *** [cmTryCompileExec] Error 1
gmake: *** [cmTryCompileExec/fast] Error 2
CMake will not be able to correctly generate this project.
Call Stack (most recent call first):
CMakeLists.txt:6 (project)
-- Configuring incomplete, errors occurred!
