- To:
- Subject: Re: [cgal-discuss] lower bound on element size
- Date: Thu, 2 Dec 2010 11:14:52 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type :content-transfer-encoding; b=Q6vchm7Vq5oOf9Y9h1DW9EUQer7HLA3JcK+Rj/q9TCaGFwAP2yN4ypyKOCaK96L4z4 tzCPc+rZ8N4S6BUhsDLSaZryLoxcJ0zUIXYTF/e707zjsCblY23l6/sXEUwkg0ZAoPP9 8pQGodQSgsHFmRIXbcz6OpqmTuKeipXVFXc+M=
Indeed, I am talking about generating tets from segmented images.
As I said, I am getting 12 orders of magnitude span in the element
sizes, which makes the resulting mesh unsuitable to some computations.
In particular, I am running out of numerical precision on such meshes
in some cases. Are there practical ways to prevent this from
happening?
Dominik
On Thu, Dec 2, 2010 at 10:44 AM, Laurent Rineau (GeometryFactory)
wrote:
> On Wednesday 01 December 2010 22:00:45 Dominik Szczerba wrote:
>> Hi
>> I need to impose LOWER bound on element size. According to the latest
>> documentaiton:
>> the radius bound: This parameter controls the size (edge length) of
>> mesh cells. Actually, it is an upper bound on the circumradii of the
>> mesh tetrahedra.
>> I can only provide the UPPER bound. However, in my cases, the smallest
>> generated element is 10 orders of magnitude smaller than the biggest
>> one, resulting in numerical precision problems in subsequent
>> computations.
>> Is there a way to specify the SMALLEST allowed element size or
>> otherwise control its size?
> My guess is that you are talking about one of the mesh generators of CGAL.
> Anyway, both the 2D-, surface-,or 3D- mesh generators of CGAL work the same
> way: you cannot specify a lower bound on the elements sizes.
> Laurent Rineau, PhD
> R&D Engineer at GeometryFactory http://www.geometryfactory.com/
> Release Manager of the CGAL Project http://www.cgal.org/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] lower bound on element size, Dominik Szczerba, 12/01/2010
- Re: [cgal-discuss] lower bound on element size, Laurent Rineau (GeometryFactory), 12/02/2010
- Re: [cgal-discuss] lower bound on element size, Dominik Szczerba, 12/02/2010
- Message not available
- Re: [cgal-discuss] lower bound on element size, Mariette Yvinec, 12/05/2010
