cgal-discuss - Re: [cgal-discuss] units used in size/distance parameters
  • To:
  • Subject: Re: [cgal-discuss] units used in size/distance parameters
  • Date: Thu, 09 Dec 2010 17:54:41 +0100
  • Organization: UPM
Hello,
As a physicist, I have to care about units sometimes. What is customary
is to use "reduced coordinates", dividing all lengths by the "system
length". So, instead of a a x a x a cube, one always deals with a 1x1x1
one, and puts the right units back at the end (this is sometimes tricky,
e.g. for derivatives). Another approach is to reduce coordinates by some
internode spacing (often called "h").
Best,
Daniel
El jue, 09-12-2010 a las 17:26 +0100, Sylvain Pion escribió:
> The distance unit is the same unit as the one that you use for
> the coordinates of your points. The others follow.
> Sylvain
