cgal-discuss - Re: [cgal-discuss] Visual studio link error
  • To:
  • Subject: Re: [cgal-discuss] Visual studio link error
  • Date: Thu, 16 Dec 2010 11:07:26 -0500
Thanks for your reply.
Yes, I am pretty sure that I was using the 3.7 version. If the auto-linking is disabled, why the compiler would ask for that file?
Maybe it is the way that I used to compile the CGAL is not right.
I am trying to re-compile the CGAL and I do not remember the file existed in that folder.
Would you please tell me where can I find the information about how to compile the CGAL for Visual Studio 2008?
Thank you very much!
Best,
Yongquan
On Thu, Dec 16, 2010 at 5:55 AM, Laurent Rineau (GeometryFactory) <> wrote:
On Wednesday 15 December 2010 18:58:23 Yongquan Yang wrote:
> I was trying to compile the surface reconstruction point 3
> file
> CGAL-3.7\examples\Surface_reconstruction_points_3\poisson_reconstruction_e
> xample.cpp with visual studio 2008.
> When I build the solution, an error occurred:
> 1>LINK : fatal error LNK1104: cannot open file 'gmp-vc90-mt-gd.lib'
Are you sure you that you are compiling using the header files of CGAL-3.7?
Since CGAL-3.7, the auto-linking of gmp and mpfr is disabled by default.
> I search my computer and no file named gmp-vc90-mt-gd.lib was found.
> Somebody said this file locates at CGAL-3.7\auxiliary\gmp\lib, but when I
> look at that folder I didn't see the file.
What do you have in CGAL-3.7\auxiliary\gmp\lib\ ?
Laurent Rineau, PhD
R&D Engineer at GeometryFactory           http://www.geometryfactory.com/
Release Manager of the CGAL Project       http://www.cgal.org/
