cgal-discuss - Re: [cgal-discuss] Re: Visual studio link error
  • To:
  • Subject: Re: [cgal-discuss] Re: Visual studio link error
  • Date: Mon, 20 Dec 2010 10:58:33 -0500
Hi John,
I renamed the file "libgmp-10.lib" in the directory \CGAL-3.7\auxiliary\gmp\libĀ  to "gmp-vc90-mt-gd.lib", the cannot found error has been solved, but there is other problems:
1>LINK : warning LNK4098: defaultlib 'MSVCRT' conflicts with use of other libs; use /NODEFAULTLIB:library
1>poisson_reconstruction_example.obj : error LNK2019: unresolved external symbol _GetProcessMemoryInfo@12 referenced in function "private: unsigned int __thiscall CGAL::Memory_sizer::get(bool)const " (?get@Memory_sizer@CGAL@@ABEI_N@Z)
1>D:\Work\Yongquan_Yang\VS_Project\Visual Studio 2008\Projects\CGALTestAgain\Debug\CGALTestAgain.exe : fatal error LNK1120: 1 unresolved externals
I have no idea whether it is the lib problem or anything else.
Thanks for your help!
Best,
Yongquan
On Sat, Dec 18, 2010 at 8:58 AM, johnzjq <> wrote:
Hi Yongquan,
Rename your file name would solve the problem.
Good Luck,
John
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Visual-studio-link-error-tp3089529p3093682.html
