cgal-discuss - [cgal-discuss] Re: Add a fresh pointer member inside Point_set_scene_item class, Heap corruption when destruction
  • To:
  • Subject: [cgal-discuss] Re: Add a fresh pointer member inside Point_set_scene_item class, Heap corruption when destruction
  • Date: Wed, 22 Dec 2010 05:28:43 -0800 (PST)
Best Regards,
Leon(Shanghai,China)
--- On Tue, 12/21/10, Laurent Rineau (GeometryFactory) [via cgal-discuss] <[hidden email]> wrote:
From: Laurent Rineau (GeometryFactory) [via cgal-discuss] <[hidden email]>
Subject: Re: Add a fresh pointer member inside Point_set_scene_item class, Heap corruption when destruction
To: "cmodel" <[hidden email]>
Date: Tuesday, December 21, 2010, 2:15 AM
        Le mardi 21 décembre 2010 04:51:49, cmodel a écrit :
> Here is the issue,
> I tried adding one pointer member, like std::vector *m_point2;
> typedef CGAL::Triangulation_2 Triangulation2;
> typedef Triangulation2::Face_handle Face_handle;
> typedef Triangulation2::Finite_faces_iterator Finite_faces_iterator;
> typedef Triangulation2::Point  Point2;
> then in destructor, add the following:
>   Q_ASSERT(m_point2 != NULL);
>   delete m_point2; m_point2 = NULL;
Replace by:
  if(m_point_2) {
    delete m_point2;
And add:
  m_point2=NULL;
in the constructor.
> in bool Point_set_scene_item::read_xyz_point_set(std::istream& stream)
> code section, add the following:
>   m_point2 = new std::vector;
Change that to:
  if(m_point2==NULL)
  else
    m_point2->clear();
> Then build the project, run, got " heap corruption debug error ", did I use
> wrong memory?
Did you clean the whole project before rebuilding it?
Leon> OK, I have cleaned the project and rebuild, it solved this issue.
Laurent Rineau, PhD
Release Manager of the CGAL Project       http://www.cgal.org/
R&D Engineer at GeometryFactory           http://www.geometryfactory.com/
                View message @ http://cgal-discuss.949826.n4.nabble.com/Add-a-fresh-pointer-member-inside-Point-set-scene-item-class-Heap-corruption-when-destruction-tp3121294p3129423.html
                To unsubscribe from Add a fresh pointer member inside Point_set_scene_item class, Heap corruption when destruction, click here.
View this message in context: Re: Add a fresh pointer member inside Point_set_scene_item class, Heap corruption when destruction
