cgal-discuss - Re: [cgal-discuss] Atoms contributing to the Connolly surface
  • To:
  • Subject: Re: [cgal-discuss] Atoms contributing to the Connolly surface
  • Date: Mon, 27 Dec 2010 11:18:53 +0900
Nico Kruithof wrote:
Not exactly, the Connolly surface is the surface obtained by rolling a ball of radius r over the union of balls. If r==0, you are right, but not if r>0.
The rolling probe sphere should represent a solvent molecule in my case (water).
The easiest way is to compute the regular triangulation of the balls (weighted points) with the radius increased by r. Then, if a Voronoi cell of a weighted point (ball) is not entirely contained within that ball, the ball contributes to the Connoly surface. This shouldn't be too hard to implement.
I see. In fact, the dot surface should be OK for me, I don't really need the Connoly surface in fact.
I think I will do this outside of CGAL if it does not include such
high level constructs as molecule.get_dot_suface() or molecule.get_Connoly_suface().
Regards,
F.
Bests,
Nico
On Tue, Dec 21, 2010 at 10:27 AM, Laurent Rineau (GeometryFactory) < <mailto:>> wrote:
On Tuesday 21 December 2010 09:29:41 Francois Berenger wrote:
> Hi,
> Using CGAL, is it easy to extract the list of atoms
> contributing to the Connolly surface for a globular
> protein?
Unless I am wrong, the Connolly surface is the skin surface with scale
factor 1.
See this chapter if you can find what you need:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Skin_surface_3/Chapter_main.html
Laurent Rineau, PhD
