cgal-discuss - Re: [cgal-discuss] build Point_Set demo error with .moc
  • To:
  • Subject: Re: [cgal-discuss] build Point_Set demo error with .moc
  • Date: Mon, 27 Dec 2010 08:36:10 +0100
cmodel wrote:
Hi all,
I have used CMake generated VC9 project for Point_Set demo. and when try
build within MSVS9, it gave errors of moc generation.
1>------ Build started: Project: PS_demo_off_plugin, Configuration: Debug
Win32 ------
1>Generating PS_demo_off_plugin.moc
1>moc: Too many input files specified
1>Usage: moc [options] <header-file>
1> -o<file> write output to file rather than stdout
1> -I<dir> add dir to the include path for header files
1> -E preprocess only; do not generate meta object code
1> -D<macro>[=<def>] define macro, with optional definition
1> -U<macro> undefine macro
1> -i do not generate an #include statement
1> -p<path> path prefix for included file
1> -f[<file>] force #include, optional file name
1> -nw do not display warnings
1> @<file> read additional options from file
1> -v display version of moc
1>Project : error PRJ0019: A tool returned an error code from "Generating
PS_demo_off_plugin.moc"
Then I tried generating MOC with batch file I used in the following:
C:\Qt\4.7.1\bin\moc.exe -D_MSC_VER=1500 -DWIN32 -o .\PS_demo_off_plugin.moc
.\PS_demo_off_plugin.cpp
Then everything looks fine. and can generate .moc file and build succeeded.
But whereafter I want to build again, it pops up strange error.
1>Compiling...
1>PS_demo_off_plugin.moc
1>.\PS_demo_off_plugin.moc(11) : fatal error C1189: #error : "The header
file 'PS_demo_off_plugin.cpp' doesn't include <QObject>."
I then tried re-generate that .moc again manually, but cannot fix it.
Then I found the following MACRO in the .moc file.
#if !defined(Q_MOC_OUTPUT_REVISION)
#error "The header file 'PS_demo_off_plugin.cpp' doesn't include <QObject>."
I don't know why I can build successfully at my first time, whereas not
working now?
Please help me. Thanks.
Leon
Is the moc.exe used by cmake the same than you manually used?
S.
