- To:
- Subject: [cgal-discuss] Re: Any idea about Minkowski difference?
- Date: Thu, 30 Dec 2010 01:43:53 -0800 (PST)
Hi, J.,
I have tested your models. At first, I came across the same assertion! Then,
I examined your model and did some modification, Finally, succeed.
1 The models you provide probably trigger some of the restrictions of
MinkowskiSum.
(S29.3
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Minkowski_sum_3/Chapter_main.html)
I converted the model to the triangle based OBJ model using 3dsmax and there
is no assertion appeared any more.
2 The l_shape is too small to produce any results after "erosion". I scaled
the original model by 4 times (or 5) and get the result as attached.
(Carelessly, I translated the coordinates of the original model. Please try
with the new models)
http://cgal-discuss.949826.n4.nabble.com/file/n3168082/cube_m.off cube_m.off
http://cgal-discuss.949826.n4.nabble.com/file/n3168082/l_shape_m.off
l_shape_m.off
http://cgal-discuss.949826.n4.nabble.com/file/n3168082/result.off result.off
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Re-Any-idea-about-Minkowski-difference-tp3166601p3168082.html
- [cgal-discuss] Any idea about Minkowski difference?, johnzjq, 12/20/2010
- Re: [cgal-discuss] Any idea about Minkowski difference?, J.L.M., 12/29/2010
- [cgal-discuss] Re: Any idea about Minkowski difference?, johnzjq, 12/29/2010
- Re: [cgal-discuss] Re: Any idea about Minkowski difference?, J.L.M., 12/29/2010
- [cgal-discuss] Re: Any idea about Minkowski difference?, johnzjq, 12/30/2010
- Re: [cgal-discuss] Re: Any idea about Minkowski difference?, J.L.M., 12/30/2010
- [cgal-discuss] Re: Any idea about Minkowski difference?, johnzjq, 12/31/2010
- <Possible follow-up(s)>
- [cgal-discuss] Re: Any ideas about Minkowski difference?, johnzjq, 12/21/2010
- [cgal-discuss] Re: Any ideas about Minkowski difference?, johnzjq, 12/22/2010
