- To:
- Subject: Re: [cgal-discuss] Re: Any idea about Minkowski difference?
- Date: Thu, 30 Dec 2010 07:43:50 -0500
John,
thanks for your help. I'm reasonably confident that my models do not violate the restrictions. I had run into those early in my work, and the assertion clearly points out when you are violating it. Attached is a picture of my model.
How are you using OBJ models in CGAL? I see that CGAL supports writing .obj files, but not reading them back in (unless I missed the documentation). The only format I see that CGAL supports for reading is OFF.
The erosion should produce exactly two lines, attached at one endpoint at a 90 degree angle. I am testing the tight passages scenario. Indeed, when I use a smaller cube, I do not get an assertion.
I do understand that there can be translation if the shapes are not properly positioned about the origin. My models always include the origin on their interior.
On 12/28/2010 09:31 PM, johnzjq wrote:
> Hi, J.,
> I have tested your models. At first, I came across the same assertion! Then, I examined your model and did some modification, Finally, succeed.
> 1 The models you provide probably trigger some of the restrictions of > MinkowskiSum.
> (S29.3 http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Minkowski_sum_3/Chapter_main.html)
> I converted the model to the triangle based OBJ model using 3dsmax and there is no assertion appeared any more.
> 2 The l_shape is too small to produce any results after "erosion". I > scaled the original model by 4 times (or 5) and get the result as attached.
> (Carelessly, I translated the coordinates of the original model. Please try with the new models)
Hi,
Many thanks for your detailed explaination. And your suggestions are really
helpful.
I have implmented the code I attached in the post "Any idea about Minkowski
difference?" and it works fine on many complex CAD models (which should be
2-manifold) , but a bit slow.
Regards,
John
Description: JPEG image
- [cgal-discuss] Any idea about Minkowski difference?, johnzjq, 12/20/2010
- Re: [cgal-discuss] Any idea about Minkowski difference?, J.L.M., 12/29/2010
- [cgal-discuss] Re: Any idea about Minkowski difference?, johnzjq, 12/29/2010
- Re: [cgal-discuss] Re: Any idea about Minkowski difference?, J.L.M., 12/29/2010
- [cgal-discuss] Re: Any idea about Minkowski difference?, johnzjq, 12/30/2010
- Re: [cgal-discuss] Re: Any idea about Minkowski difference?, J.L.M., 12/30/2010
- [cgal-discuss] Re: Any idea about Minkowski difference?, johnzjq, 12/31/2010
- <Possible follow-up(s)>
- [cgal-discuss] Re: Any ideas about Minkowski difference?, johnzjq, 12/21/2010
- [cgal-discuss] Re: Any ideas about Minkowski difference?, johnzjq, 12/22/2010
