- To:
- Subject: Re: [cgal-discuss] Ridge Edge Detection Problems
- Date: Fri, 7 Jan 2011 21:49:31 +0100
Hi,
you may want t ohave a look at this thread:
Subject: Re: [cgal-discuss] Ridges Package does not work for
very sharp features?
MArc
On Jan 6, 2011, at 7:36 AM,
wrote:
> Now I am working on ridge edge detection. I have some questions with
> problems.
> (1) Can Ridge Edge detection detect the shape-edge of the model?
> (2) [if (1) can do] I try to detect with the simple model like a cylinder of
> which the facets are from the scanner. The problem is that I would like to
> detect the sharp-edges, i.e. two circle-liked curves on the model but I
> couldn't find it. In Fig__.6 Mechanical part (37kpts), I found that
> Sharp-edges
> can detect easily with filtering the threshold, but for my case, it is not
> easy.
> Could anyone solve this problem for me, please?
> Anyway, I set the command for ridge as ___.off -d 4 -m 4 -a 4 -t -4.
> Thank you very much for your helps.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] Ridge Edge Detection Problems, skittichai, 01/06/2011
- Re: [cgal-discuss] Ridge Edge Detection Problems, Marc Pouget, 01/07/2011
- RE: [cgal-discuss] Ridge Edge Detection Problems, Kittichai S ., 01/10/2011
