- To:
- Subject: [cgal-discuss] Ridge Edge Detection Problems
- Date: Thu, 6 Jan 2011 07:36:02 +0100 (CET)
Now I am working on ridge edge detection. I have some questions with problems.
(1) Can Ridge Edge detection detect the shape-edge of the model?
(2) [if (1) can do] I try to detect with the simple model like a cylinder of
which the facets are from the scanner. The problem is that I would like to
detect the sharp-edges, i.e. two circle-liked curves on the model but I
couldn't find it. In Fig__.6 Mechanical part (37kpts), I found that
Sharp-edges
can detect easily with filtering the threshold, but for my case, it is not
easy.
Could anyone solve this problem for me, please?
Anyway, I set the command for ridge as ___.off -d 4 -m 4 -a 4 -t -4.
Thank you very much for your helps.
- [cgal-discuss] Ridge Edge Detection Problems, skittichai, 01/06/2011
- Re: [cgal-discuss] Ridge Edge Detection Problems, Marc Pouget, 01/07/2011
- RE: [cgal-discuss] Ridge Edge Detection Problems, Kittichai S ., 01/10/2011
