Re: [cgal-discuss] Compilation error (bug?): c all of overloaded ‘fit_in_double(const CGAL ::Lazy_exact_nt<CGAL::Gmpq>&, double&)’ is ambiguous
- To:
- Subject: Re: [cgal-discuss] Compilation error (bug?): c all of overloaded ‘fit_in_double(const CGAL ::Lazy_exact_nt<CGAL::Gmpq>&, double&)’ is ambiguous
- Date: Wed, 12 Jan 2011 10:06:40 +0100
This problem has already been corrected.
Here is the patch file to replace.
S.
maag3377 wrote:
Hi,
I believe this is related to the following report:
http://cgal-discuss.949826.n4.nabble.com/CGAL-Python-on-Mac-td3196194.html
I get strange compilation errors when compiling the following code with g++
-c -g cgal.cpp using CGAL 3.7:
// cgal.cpp
#include <CGAL/MP_Float.h>
#include <CGAL/Lazy_exact_nt.h>
#include <CGAL/Quotient.h>
#include <CGAL/Simple_cartesian.h>
#include <CGAL/Filtered_kernel.h>
#include <CGAL/Polygon_2.h>
#include <CGAL/partition_2.h>
#include <CGAL/Partition_traits_2.h>
typedef
CGAL::Filtered_kernel<CGAL::Simple_cartesian<CGAL::Lazy_exact_nt<CGAL::Gmpq
typedef CGAL::Partition_traits_2<Kernel> Traits;Kernel;
typedef Traits::Point_2 Point_2;
typedef Traits::Polygon_2 Polygon_2;
void make_polygon(Polygon_2& polygon)
polygon.push_back(Point_2(391, 374));
polygon.push_back(Point_2(240, 431));
polygon.push_back(Point_2(252, 340));
polygon.push_back(Point_2(374, 320));
polygon.push_back(Point_2(289, 214));
polygon.push_back(Point_2(134, 390));
polygon.push_back(Point_2( 68, 186));
polygon.push_back(Point_2(154, 259));
polygon.push_back(Point_2(161, 107));
polygon.push_back(Point_2(435, 108));
polygon.push_back(Point_2(208, 148));
polygon.push_back(Point_2(295, 160));
polygon.push_back(Point_2(421, 212));
polygon.push_back(Point_2(441, 303));
void partition() {
Polygon_2 polygon;
make_polygon(polygon);
std::list<Polygon_2> result;
Traits partition_traits;
CGAL::greene_approx_convex_partition_2(polygon.vertices_begin(), polygon.vertices_end(),
std::back_inserter(result),
partition_traits);
I get the following errors:
In file included from
/usr/local/include/CGAL/internal/Static_filters/Static_filters.h:38,
from /usr/local/include/CGAL/Filtered_kernel.h:35,
from cgal.cpp:7:
/usr/local/include/CGAL/internal/Static_filters/Orientation_2.h: In member
function ‘CGAL::Orientation
CGAL::internal::Static_filters_predicates::Orientation_2<K_base>::operator()(const
typename K_base::Point_2&, const typename K_base::Point_2&, const typename
K_base::Point_2&) const [with K_base =
CGAL::Filtered_kernel_base<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<CGAL::Lazy_exact_nt<CGAL::Gmpq>,
CGAL::Filtered_kernel<CGAL::Simple_cartesian<CGAL::Lazy_exact_nt<CGAL::Gmpq>
, true> >,CGAL::Filtered_kernel<CGAL::Simple_cartesian<CGAL::Lazy_exact_nt<CGAL::Gmpq>
, true> > >]’:/usr/local/include/CGAL/Polygon_2/Polygon_2_algorithms_impl.h:436: instantiated from ‘CGAL::Orientation CGAL::orientation_2(ForwardIterator,
ForwardIterator, const Traits&) [with ForwardIterator =
std::_List_iterator<CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<CGAL::Lazy_exact_nt<CGAL::Gmpq>
, true> > >, Traits =CGAL::Partition_traits_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<CGAL::Lazy_exact_nt<CGAL::Gmpq>
, true> >]’/usr/local/include/CGAL/Partition_2/partition_greene_approx_convex_2.h:815: instantiated from ‘OutputIterator
CGAL::partition_greene_approx_convex_2(InputIterator, InputIterator,
OutputIterator, const Traits&) [with InputIterator =
, true> > >, OutputIterator =std::back_insert_iterator<std::list<CGAL::Polygon_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<CGAL::Lazy_exact_nt<CGAL::Gmpq>
, true>,std::list<CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<CGAL::Lazy_exact_nt<CGAL::Gmpq>
, true> >,std::allocator<CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<CGAL::Lazy_exact_nt<CGAL::Gmpq>
, true> > > > >,std::allocator<CGAL::Polygon_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<CGAL::Lazy_exact_nt<CGAL::Gmpq>
, true> > > > > > > >, Traits =CGAL::Partition_traits_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<CGAL::Lazy_exact_nt<CGAL::Gmpq>
, true> >]’/usr/local/include/CGAL/partition_2.h:37: instantiated from
‘OutputIterator CGAL::greene_approx_convex_partition_2(InputIterator,
InputIterator, OutputIterator, const Traits&) [with InputIterator =
, true> > > > > > > >, Traits = Traits]’cgal.cpp:48: instantiated from here
/usr/local/include/CGAL/internal/Static_filters/Orientation_2.h:69: error:
call of overloaded ‘fit_in_double(const CGAL::Lazy_exact_nt<CGAL::Gmpq>&,
/usr/local/include/CGAL/internal/Static_filters/tools.h:55: note: candidates
are: bool CGAL::internal::fit_in_double(const T&, double&) [with T =
CGAL::Lazy_exact_nt<CGAL::Gmpq>]
/usr/local/include/CGAL/internal/Static_filters/tools.h:64: note: bool CGAL::internal::fit_in_double(const CGAL::Lazy_exact_nt<ET>&, double&)
[with ET = CGAL::Gmpq]
/usr/local/include/CGAL/Lazy_exact_nt.h:1275: note: bool
CGAL::fit_in_double(const CGAL::Lazy_exact_nt<ET>&, double&) [with ET =
CGAL::Gmpq]
CGAL::Gmpq]
CGAL::Gmpq]
CGAL::Gmpq]
CGAL::Gmpq]
CGAL::Gmpq]
There is an ambiguous call to fit_in_double() which is defined in
CGAL/internal/Static_filters/tools.h.
Looking in that file, the declaration in the end of the file
inline bool fit_in_double(const Lazy_exact_nt<ET>&, double&);
seems to clash with the definition
inline bool fit_in_double(const T&, double&) { return false; }
further up in the file.
When I uncomment the declaration and rebuild CGAL everything compiles fine.
What is your idea on this?
Regards,
Magnus
// Copyright (c) 1999-2007 INRIA Sophia-Antipolis (France). // All rights reserved. // // This file is part of CGAL (www.cgal.org); you can redistribute it and/or // modify it under the terms of the GNU Lesser General Public License as // published by the Free Software Foundation; version 2.1 of the License. // See the file LICENSE.LGPL distributed with CGAL. // // Licensees holding a valid commercial license may use this file in // accordance with the commercial license agreement provided with the software. // // This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE // WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. // // $URL: svn+ssh:///svn/cgal/branches/CGAL-3.7-branch/Number_types/include/CGAL/Lazy_exact_nt.h $ // $Id: Lazy_exact_nt.h 59725 2010-11-16 11:53:38Z lrineau $ // // // Author(s) : Sylvain Pion #ifndef CGAL_LAZY_EXACT_NT_H #define CGAL_LAZY_EXACT_NT_H #define CGAL_int(T) typename First_if_different<int, T>::Type #define CGAL_double(T) typename First_if_different<double, T>::Type #define CGAL_To_interval(T) To_interval<T> #include <CGAL/number_type_basic.h> #include <boost/iterator/transform_iterator.hpp> // for Root_of functor #include <boost/static_assert.hpp> #include <boost/operators.hpp> #include <CGAL/Interval_nt.h> #include <CGAL/Handle.h> #include <CGAL/NT_converter.h> #include <CGAL/Profile_counter.h> #include <CGAL/Lazy.h> // #include <CGAL/Root_of_traits.h> // TODO /* * This file contains the definition of the number type Lazy_exact_nt<ET>, * where ET is an exact number type (must provide the exact operations needed). * * Lazy_exact_nt<ET> provides a DAG-based lazy evaluation, like LEDA's real, * Core's Expr, LEA's lazy rationals... * * The values are first approximated using Interval_base. * The exactness is provided when needed by ET. * * Lazy_exact_nt<ET> is just a handle to the abstract base class * Lazy_exact_nt_rep which has pure virtual methods .approx() and .exact(). * From this class derives one class per operation, with one constructor. * * The DAG is managed by : * - Handle and Rep. * - virtual functions to denote the various operators (instead of an enum). * * Other packages with vaguely similar design : APU, MetaCGAL, LOOK. */ /* * TODO : * - Generalize it for constructions at the kernel level. * - Add mixed operations with ET too ? * - Interval refinement functionnality ? * - Separate the handle and the representation(s) in 2 files (?) * maybe not a good idea, better if everything related to one operation is * close together. * - Add a CT template parameter ? * - Add a string constant to provide an expression string (a la MetaCGAL) ? * // virtual ostream operator<<() const = 0; // or string, like Core ? * - Have a template-expression (?) thing that evaluates a temporary element, * and allocates stuff in memory only when really needs to convert to the * NT. (cf gmp++, and maybe other things, Blitz++, Synaps...) */ /* * Interface of the rep classes: * - .approx() returns Interval_nt<> (assumes rounding=nearest). * [ only called from the handle, and declared in the base ] * - .exact() returns ET, if not already done, computes recursively * * - .rafine_approx() ?? */ namespace CGAL { template <class NT> class Lazy_exact_nt; // Abstract base representation class for lazy numbers template <typename ET> struct Lazy_exact_nt_rep : public Lazy_exact_nt<ET>::Self_rep { typedef typename Lazy_exact_nt<ET>::Self_rep Base; Lazy_exact_nt_rep (const Interval_nt<false> & i) : Base(i) {} #ifdef CGAL_LAZY_KERNEL_DEBUG void print_dag(std::ostream& os, int level) const { this->print_at_et(os, level); } #endif }; // int constant template <typename ET> struct Lazy_exact_Int_Cst : public Lazy_exact_nt_rep<ET> { Lazy_exact_Int_Cst (int i) : Lazy_exact_nt_rep<ET>(double(i)) {} void update_exact() const { this->et = new ET((int)this->approx().inf()); } }; // double constant template <typename ET> struct Lazy_exact_Cst : public Lazy_exact_nt_rep<ET> { Lazy_exact_Cst (double d) : Lazy_exact_nt_rep<ET>(d) {} void update_exact() const { this->et = new ET(this->approx().inf()); } }; // Exact constant template <typename ET> struct Lazy_exact_Ex_Cst : public Lazy_exact_nt_rep<ET> { Lazy_exact_Ex_Cst (const ET & e) : Lazy_exact_nt_rep<ET>(CGAL_NTS to_interval(e)) { this->et = new ET(e); } void update_exact() const { CGAL_error(); } }; // Construction from a Lazy_exact_nt<ET1> (which keeps the lazyness). template <typename ET, typename ET1> class Lazy_lazy_exact_Cst : public Lazy_exact_nt_rep<ET> { mutable Lazy_exact_nt<ET1> l; public: Lazy_lazy_exact_Cst (const Lazy_exact_nt<ET1> &x) : Lazy_exact_nt_rep<ET>(x.approx()), l(x) { this->set_depth(l.depth() + 1); } void update_exact() const { this->et = new ET(l.exact()); this->at = l.approx(); prune_dag(); } void prune_dag() const { l = Lazy_exact_nt<ET1>(); } }; // Unary operations: abs, sqrt, square. // Binary operations: +, -, *, /, min, max. // Base unary operation template <typename ET> struct Lazy_exact_unary : public Lazy_exact_nt_rep<ET> { mutable Lazy_exact_nt<ET> op1; Lazy_exact_unary (const Interval_nt<false> &i, const Lazy_exact_nt<ET> &a) : Lazy_exact_nt_rep<ET>(i), op1(a) { this->set_depth(op1.depth() + 1); } void prune_dag() const { op1 = Lazy_exact_nt<ET>(); } #ifdef CGAL_LAZY_KERNEL_DEBUG void print_dag(std::ostream& os, int level) const { this->print_at_et(os, level); if(this->is_lazy()){ msg(os, level, "Unary number operator:"); print_dag(op1, os, level+1); } } #endif }; // Base binary operation template <typename ET, typename ET1 = ET, typename ET2 = ET> struct Lazy_exact_binary : public Lazy_exact_nt_rep<ET> { mutable Lazy_exact_nt<ET1> op1; mutable Lazy_exact_nt<ET2> op2; Lazy_exact_binary (const Interval_nt<false> &i, const Lazy_exact_nt<ET1> &a, const Lazy_exact_nt<ET2> &b) : Lazy_exact_nt_rep<ET>(i), op1(a), op2(b) { this->set_depth((std::max)(op1.depth(), op2.depth()) + 1); } void prune_dag() const { op1 = Lazy_exact_nt<ET1>(); op2 = Lazy_exact_nt<ET2>(); } #ifdef CGAL_LAZY_KERNEL_DEBUG void print_dag(std::ostream& os, int level) const { this->print_at_et(os, level); if(this->is_lazy()){ msg(os, level, "Binary number operator:"); print_dag(op1, os, level+1); print_dag(op2, os, level+1); } } #endif }; // Here we could use a template class for all operations (STL provides // function objects plus, minus, multiplies, divides...). But it would require // a template template parameter, and GCC 2.95 seems to crash easily with them. // Macro for unary operations #define CGAL_LAZY_UNARY_OP(OP, NAME) \ template <typename ET> \ struct NAME : public Lazy_exact_unary<ET> \ { \ typedef typename Lazy_exact_unary<ET>::AT::Protector P; \ NAME (const Lazy_exact_nt<ET> &a) \ : Lazy_exact_unary<ET>((P(), OP(a.approx())), a) {} \ \ void update_exact() const \ { \ this->et = new ET(OP(this->op1.exact())); \ if (!this->approx().is_point()) \ this->at = CGAL_NTS to_interval(*(this->et)); \ this->prune_dag(); \ } \ }; CGAL_LAZY_UNARY_OP(opposite, Lazy_exact_Opp) CGAL_LAZY_UNARY_OP(CGAL_NTS abs, Lazy_exact_Abs) CGAL_LAZY_UNARY_OP(CGAL_NTS square, Lazy_exact_Square) CGAL_LAZY_UNARY_OP(CGAL_NTS sqrt, Lazy_exact_Sqrt) // A macro for +, -, * and / #define CGAL_LAZY_BINARY_OP(OP, NAME) \ template <typename ET, typename ET1 = ET, typename ET2 = ET> \ struct NAME : public Lazy_exact_binary<ET, ET1, ET2> \ { \ typedef typename Lazy_exact_binary<ET,ET1,ET2>::AT::Protector P; \ NAME (const Lazy_exact_nt<ET1> &a, const Lazy_exact_nt<ET2> &b) \ : Lazy_exact_binary<ET, ET1, ET2>((P(), a.approx() OP b.approx()), a, b) {} \ \ void update_exact() const \ { \ this->et = new ET(this->op1.exact() OP this->op2.exact()); \ if (!this->approx().is_point()) \ this->at = CGAL_NTS to_interval(*(this->et)); \ this->prune_dag(); \ } \ }; CGAL_LAZY_BINARY_OP(+, Lazy_exact_Add) CGAL_LAZY_BINARY_OP(-, Lazy_exact_Sub) CGAL_LAZY_BINARY_OP(*, Lazy_exact_Mul) CGAL_LAZY_BINARY_OP(/, Lazy_exact_Div) // Minimum template <typename ET> struct Lazy_exact_Min : public Lazy_exact_binary<ET> { Lazy_exact_Min (const Lazy_exact_nt<ET> &a, const Lazy_exact_nt<ET> &b) : Lazy_exact_binary<ET>((CGAL::min)(a.approx(), b.approx()), a, b) {} void update_exact() const { this->et = new ET((CGAL::min)(this->op1.exact(), this->op2.exact())); if (!this->approx().is_point()) this->at = CGAL_NTS to_interval(*(this->et)); this->prune_dag(); } }; // Maximum template <typename ET> struct Lazy_exact_Max : public Lazy_exact_binary<ET> { Lazy_exact_Max (const Lazy_exact_nt<ET> &a, const Lazy_exact_nt<ET> &b) : Lazy_exact_binary<ET>((CGAL::max)(a.approx(), b.approx()), a, b) {} void update_exact() const { this->et = new ET((CGAL::max)(this->op1.exact(), this->op2.exact())); if (!this->approx().is_point()) this->at = CGAL_NTS to_interval(*(this->et)); this->prune_dag(); } }; // The real number type, handle class template <typename ET_> class Lazy_exact_nt : public Lazy<Interval_nt<false>, ET_, Lazy_exact_nt<ET_>, To_interval<ET_> > , boost::ordered_euclidian_ring_operators2< Lazy_exact_nt<ET_>, int > , boost::ordered_euclidian_ring_operators2< Lazy_exact_nt<ET_>, double > { public: typedef Lazy_exact_nt<ET_> Self; typedef Lazy<Interval_nt<false>, ET_, Self, To_interval<ET_> > Base; typedef typename Base::Self_rep Self_rep; typedef typename Base::ET ET; // undocumented typedef typename Base::AT AT; // undocumented typedef typename Base::Exact_type Exact_type; typedef typename Base::Approximate_type Approximate_type; public : Lazy_exact_nt () {} Lazy_exact_nt (Self_rep *r) : Base(r) {} Lazy_exact_nt (const CGAL_int(ET) & i) : Base(new Lazy_exact_Int_Cst<ET>(i)) {} Lazy_exact_nt (unsigned i) : Base(new Lazy_exact_Cst<ET>(i)){} Lazy_exact_nt (const CGAL_double(ET) & d) : Base(new Lazy_exact_Cst<ET>(d)){} Lazy_exact_nt (const ET & e) : Base(new Lazy_exact_Ex_Cst<ET>(e)){} template <class ET1> Lazy_exact_nt (const Lazy_exact_nt<ET1> &x) : Base(new Lazy_lazy_exact_Cst<ET, ET1>(x)){} Self operator+ () const { return *this; } Self operator- () const { return new Lazy_exact_Opp<ET>(*this); } Self & operator+=(const Self& b) { return *this = new Lazy_exact_Add<ET>(*this, b); } Self & operator-=(const Self& b) { return *this = new Lazy_exact_Sub<ET>(*this, b); } Self & operator*=(const Self& b) { return *this = new Lazy_exact_Mul<ET>(*this, b); } Self & operator/=(const Self& b) { CGAL_precondition(b != 0); return *this = new Lazy_exact_Div<ET>(*this, b); } // Mixed operators. (could be optimized ?) Self & operator+=(CGAL_int(ET) b) { return *this = new Lazy_exact_Add<ET>(*this, b); } Self & operator-=(CGAL_int(ET) b) { return *this = new Lazy_exact_Sub<ET>(*this, b); } Self & operator*=(CGAL_int(ET) b) { return *this = new Lazy_exact_Mul<ET>(*this, b); } Self & operator/=(CGAL_int(ET) b) { CGAL_precondition(b != 0); return *this = new Lazy_exact_Div<ET>(*this, b); } Self & operator+=(CGAL_double(ET) b) { return *this = new Lazy_exact_Add<ET>(*this, b); } Self & operator-=(CGAL_double(ET) b) { return *this = new Lazy_exact_Sub<ET>(*this, b); } Self & operator*=(CGAL_double(ET) b) { return *this = new Lazy_exact_Mul<ET>(*this, b); } Self & operator/=(CGAL_double(ET) b) { CGAL_precondition(b != 0); return *this = new Lazy_exact_Div<ET>(*this, b); } // % kills filtering Self & operator%=(const Self& b) { CGAL_precondition(b != 0); ET res = this->exact(); res %= b.exact(); return *this = Lazy_exact_nt<ET>(res); } Self & operator%=(int b) { CGAL_precondition(b != 0); ET res = this->exact(); res %= b; return *this = Lazy_exact_nt<ET>(res); } Interval_nt<true> interval() const { const Interval_nt<false>& i = this->approx(); return Interval_nt<true>(i.inf(), i.sup()); } Interval_nt_advanced approx_adv() const { return this->ptr()->approx(); } static const double & get_relative_precision_of_to_double() { return relative_precision_of_to_double; } static void set_relative_precision_of_to_double(const double & d) { CGAL_assertion((0 < d) & (d < 1)); relative_precision_of_to_double = d; } bool identical(const Self& b) const { return ::CGAL::identical( static_cast<const Handle &>(*this), static_cast<const Handle &>(b)); } template < typename T > bool identical(const T&) const { return false; } private: static double relative_precision_of_to_double; }; template <typename ET> double Lazy_exact_nt<ET>::relative_precision_of_to_double = 0.00001; template <typename ET1, typename ET2> bool operator<(const Lazy_exact_nt<ET1>& a, const Lazy_exact_nt<ET2>& b) { CGAL_BRANCH_PROFILER(std::string(" failures/calls to : ") + std::string(CGAL_PRETTY_FUNCTION), tmp); if (a.identical(b)) return false; Uncertain<bool> res = a.approx() < b.approx(); if (is_certain(res)) return get_certain(res); CGAL_BRANCH_PROFILER_BRANCH(tmp); return a.exact() < b.exact(); } template <typename ET1, typename ET2> bool operator==(const Lazy_exact_nt<ET1>& a, const Lazy_exact_nt<ET2>& b) { CGAL_BRANCH_PROFILER(std::string(" failures/calls to : ") + std::string(CGAL_PRETTY_FUNCTION), tmp); if (a.identical(b)) return true; Uncertain<bool> res = a.approx() == b.approx(); if (is_certain(res)) return get_certain(res); CGAL_BRANCH_PROFILER_BRANCH(tmp); return a.exact() == b.exact(); } template <typename ET1, typename ET2> inline bool operator>(const Lazy_exact_nt<ET1>& a, const Lazy_exact_nt<ET2>& b) { return b < a; } template <typename ET1, typename ET2> inline bool operator>=(const Lazy_exact_nt<ET1>& a, const Lazy_exact_nt<ET2>& b) { return ! (a < b); } template <typename ET1, typename ET2> inline bool operator<=(const Lazy_exact_nt<ET1>& a, const Lazy_exact_nt<ET2>& b) { return b >= a; } template <typename ET1, typename ET2> inline bool operator!=(const Lazy_exact_nt<ET1>& a, const Lazy_exact_nt<ET2>& b) { return ! (a == b); } template <typename ET> inline Lazy_exact_nt<ET> operator%(const Lazy_exact_nt<ET>& a, const Lazy_exact_nt<ET>& b) { CGAL_PROFILER(std::string("calls to : ") + std::string(CGAL_PRETTY_FUNCTION)); CGAL_precondition(b != 0); return Lazy_exact_nt<ET>(a) %= b; } // Mixed operators with int. template <typename ET> bool operator<(const Lazy_exact_nt<ET>& a, int b) { CGAL_BRANCH_PROFILER(std::string(" failures/calls to : ") + std::string(CGAL_PRETTY_FUNCTION), tmp); Uncertain<bool> res = a.approx() < b; if (is_certain(res)) return res; CGAL_BRANCH_PROFILER_BRANCH(tmp); return a.exact() < b; } template <typename ET> bool operator>(const Lazy_exact_nt<ET>& a, int b) { CGAL_BRANCH_PROFILER(std::string(" failures/calls to : ") + std::string(CGAL_PRETTY_FUNCTION), tmp); Uncertain<bool> res = b < a.approx(); if (is_certain(res)) return get_certain(res); CGAL_BRANCH_PROFILER_BRANCH(tmp); return b < a.exact(); } template <typename ET> bool operator==(const Lazy_exact_nt<ET>& a, int b) { CGAL_BRANCH_PROFILER(std::string(" failures/calls to : ") + std::string(CGAL_PRETTY_FUNCTION), tmp); Uncertain<bool> res = b == a.approx(); if (is_certain(res)) return get_certain(res); CGAL_BRANCH_PROFILER_BRANCH(tmp); return b == a.exact(); } // Mixed operators with double. template <typename ET> bool operator<(const Lazy_exact_nt<ET>& a, double b) { CGAL_BRANCH_PROFILER(std::string(" failures/calls to : ") + std::string(CGAL_PRETTY_FUNCTION), tmp); Uncertain<bool> res = a.approx() < b; if (is_certain(res)) return res; CGAL_BRANCH_PROFILER_BRANCH(tmp); return a.exact() < b; } template <typename ET> bool operator>(const Lazy_exact_nt<ET>& a, double b) { CGAL_BRANCH_PROFILER(std::string(" failures/calls to : ") + std::string(CGAL_PRETTY_FUNCTION), tmp); Uncertain<bool> res = b < a.approx(); if (is_certain(res)) return res; CGAL_BRANCH_PROFILER_BRANCH(tmp); return b < a.exact(); } template <typename ET> bool operator==(const Lazy_exact_nt<ET>& a, double b) { CGAL_BRANCH_PROFILER(std::string(" failures/calls to : ") + std::string(CGAL_PRETTY_FUNCTION), tmp); Uncertain<bool> res = b == a.approx(); if (is_certain(res)) return res; CGAL_BRANCH_PROFILER_BRANCH(tmp); return b == a.exact(); } template <typename ET1, typename ET2> Lazy_exact_nt< typename Coercion_traits<ET1, ET2>::Type > operator+(const Lazy_exact_nt<ET1>& a, const Lazy_exact_nt<ET2>& b) { CGAL_PROFILER(std::string("calls to : ") + std::string(CGAL_PRETTY_FUNCTION)); return new Lazy_exact_Add<typename Coercion_traits<ET1, ET2>::Type, ET1, ET2>(a, b); } template <typename ET1, typename ET2> Lazy_exact_nt< typename Coercion_traits<ET1, ET2>::Type > operator-(const Lazy_exact_nt<ET1>& a, const Lazy_exact_nt<ET2>& b) { CGAL_PROFILER(std::string("calls to : ") + std::string(CGAL_PRETTY_FUNCTION)); return new Lazy_exact_Sub<typename Coercion_traits<ET1, ET2>::Type, ET1, ET2>(a, b); } template <typename ET1, typename ET2> Lazy_exact_nt< typename Coercion_traits<ET1, ET2>::Type > operator*(const Lazy_exact_nt<ET1>& a, const Lazy_exact_nt<ET2>& b) { CGAL_PROFILER(std::string("calls to : ") + std::string(CGAL_PRETTY_FUNCTION)); return new Lazy_exact_Mul<typename Coercion_traits<ET1, ET2>::Type, ET1, ET2>(a, b); } template <typename ET1, typename ET2> Lazy_exact_nt< typename Coercion_traits<ET1, ET2>::Type > operator/(const Lazy_exact_nt<ET1>& a, const Lazy_exact_nt<ET2>& b) { CGAL_PROFILER(std::string("calls to : ") + std::string(CGAL_PRETTY_FUNCTION)); CGAL_precondition(b != 0); return new Lazy_exact_Div<typename Coercion_traits<ET1, ET2>::Type, ET1, ET2>(a, b); } // // Algebraic structure traits // namespace INTERN_LAZY_EXACT_NT { template< class NT, class Functor > struct Simplify_selector { struct Simplify : public std::unary_function<NT&, void> { void operator()( NT& ) const { // TODO: In the old implementation the Simplify-functor was the default // (which does nothing). But this cannot be the correct way!? } }; }; template< class NT > struct Simplify_selector< NT, Null_functor > { typedef Null_functor Simplify; }; template< class NT, class Functor > struct Unit_part_selector { struct Unit_part : public std::unary_function<NT, NT > { NT operator()( const NT& x ) const { return NT( CGAL_NTS unit_part( x.exact() ) ); } }; }; template< class NT > struct Unit_part_selector< NT, Null_functor > { typedef Null_functor Unit_part; }; template< class NT, class Functor > struct Is_zero_selector { struct Is_zero : public std::unary_function<NT, bool > { bool operator()( const NT& x ) const { return CGAL_NTS is_zero( x.exact() ); } }; }; template< class NT > struct Is_zero_selector< NT, Null_functor > { typedef Null_functor Is_zero; }; template< class NT, class Functor > struct Is_one_selector { struct Is_one : public std::unary_function<NT, bool > { bool operator()( const NT& x ) const { return CGAL_NTS is_one( x.exact() ); } }; }; template< class NT > struct Is_one_selector< NT, Null_functor > { typedef Null_functor Is_one; }; template< class NT, class Functor > struct Square_selector { struct Square : public std::unary_function<NT, NT > { NT operator()( const NT& x ) const { CGAL_PROFILER(std::string("calls to : ") + std::string(CGAL_PRETTY_FUNCTION)); return new Lazy_exact_Square<typename NT::ET>(x); } }; }; template< class NT > struct Square_selector< NT, Null_functor > { typedef Null_functor Square; }; template< class NT, class Functor > struct Integral_division_selector { struct Integral_division : public std::binary_function<NT, NT, NT > { NT operator()( const NT& x, const NT& y ) const { return NT( CGAL_NTS integral_division( x.exact(), y.exact() ) ); } CGAL_IMPLICIT_INTEROPERABLE_BINARY_OPERATOR( NT ) }; }; template< class NT > struct Integral_division_selector< NT, Null_functor > { typedef Null_functor Integral_division; }; template< class NT, class Functor > struct Is_square_selector { struct Is_square : public std::binary_function<NT, NT&, bool > { bool operator()( const NT& x, NT& y ) const { typename NT::ET y_et; bool result = CGAL_NTS is_square( x.exact(), y_et ); y = NT(y_et); return result; } bool operator()( const NT& x) const { typename NT::ET y_et; return CGAL_NTS is_square( x.exact(), y_et ); } }; }; template< class NT > struct Is_square_selector< NT, Null_functor > { typedef Null_functor Is_square; }; template <class NT, class AlgebraicStructureTag> struct Sqrt_selector{ struct Sqrt : public std::unary_function<NT, NT > { NT operator ()(const NT& x) const { CGAL_PROFILER(std::string("calls to : ") + std::string(CGAL_PRETTY_FUNCTION)); CGAL_precondition(x >= 0); return new Lazy_exact_Sqrt<typename NT::ET>(x); } }; }; template <class NT> struct Sqrt_selector<NT,Null_functor> { typedef Null_functor Sqrt; }; template< class NT, class Functor > struct Kth_root_selector { struct Kth_root : public std::binary_function<int, NT, NT > { NT operator()( int k, const NT& x ) const { return NT( CGAL_NTS kth_root( k, x.exact() ) ); } }; }; template< class NT > struct Kth_root_selector< NT, Null_functor > { typedef Null_functor Kth_root; }; template< class NT, class Functor > struct Root_of_selector { private: struct Cast{ typedef typename NT::ET result_type; result_type operator()(const NT& lazy_exact) const { return lazy_exact.exact(); } }; public: struct Root_of { // typedef typename Functor::Boundary Boundary; typedef NT result_type; template< class Input_iterator > NT operator()( int k, Input_iterator begin, Input_iterator end ) const { Cast cast; return NT( typename Algebraic_structure_traits<typename NT::ET>:: Root_of()( k, ::boost::make_transform_iterator( begin, cast ), ::boost::make_transform_iterator( end, cast ) ) ); } }; }; template< class NT > struct Root_of_selector< NT, Null_functor > { typedef Null_functor Root_of; }; template< class NT, class Functor > struct Gcd_selector { struct Gcd : public std::binary_function<NT, NT, NT > { NT operator()( const NT& x, const NT& y ) const { CGAL_PROFILER(std::string("calls to : ") + std::string(CGAL_PRETTY_FUNCTION)); return NT( CGAL_NTS gcd( x.exact(), y.exact() ) ); } CGAL_IMPLICIT_INTEROPERABLE_BINARY_OPERATOR( NT ) }; }; template< class NT > struct Gcd_selector< NT, Null_functor > { typedef Null_functor Gcd; }; template< class NT, class Functor > struct Div_selector { struct Div : public std::binary_function<NT, NT, NT > { NT operator()( const NT& x, const NT& y ) const { return NT( CGAL_NTS div( x.exact(), y.exact() ) ); } CGAL_IMPLICIT_INTEROPERABLE_BINARY_OPERATOR( NT ) }; }; template< class NT > struct Div_selector< NT, Null_functor > { typedef Null_functor Div; }; template< class NT, class Functor > struct Mod_selector { struct Mod : public std::binary_function<NT, NT, NT > { NT operator()( const NT& x, const NT& y ) const { return NT( CGAL_NTS mod( x.exact(), y.exact() ) ); } CGAL_IMPLICIT_INTEROPERABLE_BINARY_OPERATOR( NT ) }; }; template< class NT > struct Mod_selector< NT, Null_functor > { typedef Null_functor Mod; }; template< class NT, class Functor > struct Div_mod_selector { struct Div_mod { typedef void result_type; typedef NT first_argument_type; typedef NT second_argument_type; typedef NT& third_argument_type; typedef NT& fourth_argument_type; void operator()( const NT& x, const NT& y, NT& q, NT& r ) const { typename NT::ET q_et; typename NT::ET r_et; CGAL_NTS div_mod( x.exact(), y.exact(), q_et, r_et ); q = NT( q_et ); r = NT( r_et ); } template< class NT1, class NT2 > void operator()( const NT1& x, const NT2& y, NT& q, NT& r ) const { BOOST_STATIC_ASSERT((::boost::is_same< typename Coercion_traits< NT1, NT2 >::Type, NT >::value)); typename Coercion_traits< NT1, NT2 >::Cast cast; operator()( cast(x), cast(y), q, r ); } }; }; template< class NT > struct Div_mod_selector< NT, Null_functor >{ typedef Null_functor Div_mod; }; } // namespace INTERN_LAZY_EXACT_NT template <class ET> class Algebraic_structure_traits< Lazy_exact_nt<ET> > :public Algebraic_structure_traits_base < Lazy_exact_nt<ET>, typename Algebraic_structure_traits<ET>::Algebraic_category > { private: typedef Algebraic_structure_traits<ET> AST_ET; typedef typename AST_ET::Algebraic_category ET_as_tag; public: typedef typename AST_ET::Is_exact Is_exact; typedef typename AST_ET::Is_numerical_sensitive Is_numerical_sensitive; typedef typename INTERN_LAZY_EXACT_NT::Simplify_selector <Lazy_exact_nt<ET>, typename AST_ET::Simplify > ::Simplify Simplify; typedef typename INTERN_LAZY_EXACT_NT::Unit_part_selector <Lazy_exact_nt<ET>, typename AST_ET::Unit_part > ::Unit_part Unit_part; typedef typename INTERN_LAZY_EXACT_NT::Is_zero_selector <Lazy_exact_nt<ET>, typename AST_ET::Is_zero > ::Is_zero Is_zero; typedef typename INTERN_LAZY_EXACT_NT::Is_one_selector <Lazy_exact_nt<ET>, typename AST_ET::Is_one > ::Is_one Is_one; typedef typename INTERN_LAZY_EXACT_NT::Square_selector <Lazy_exact_nt<ET>, typename AST_ET::Square > ::Square Square; typedef typename INTERN_LAZY_EXACT_NT::Integral_division_selector <Lazy_exact_nt<ET>, typename AST_ET::Integral_division> ::Integral_division Integral_division; typedef typename INTERN_LAZY_EXACT_NT::Is_square_selector <Lazy_exact_nt<ET>, typename AST_ET::Is_square > ::Is_square Is_square; typedef typename INTERN_LAZY_EXACT_NT::Sqrt_selector <Lazy_exact_nt<ET>, typename AST_ET::Sqrt> ::Sqrt Sqrt; typedef typename INTERN_LAZY_EXACT_NT::Kth_root_selector <Lazy_exact_nt<ET>, typename AST_ET::Kth_root > ::Kth_root Kth_root; typedef typename INTERN_LAZY_EXACT_NT::Root_of_selector <Lazy_exact_nt<ET>, typename AST_ET::Root_of > ::Root_of Root_of; typedef typename INTERN_LAZY_EXACT_NT::Gcd_selector <Lazy_exact_nt<ET>, typename AST_ET::Gcd > ::Gcd Gcd; typedef typename INTERN_LAZY_EXACT_NT::Div_selector <Lazy_exact_nt<ET>, typename AST_ET::Div > ::Div Div; typedef typename INTERN_LAZY_EXACT_NT::Mod_selector <Lazy_exact_nt<ET>, typename AST_ET::Mod > ::Mod Mod; typedef typename INTERN_LAZY_EXACT_NT::Div_mod_selector <Lazy_exact_nt<ET>, typename AST_ET::Div_mod > ::Div_mod Div_mod; }; // // Real embeddalbe traits // template < typename ET > class Real_embeddable_traits< Lazy_exact_nt<ET> > : public INTERN_RET::Real_embeddable_traits_base< Lazy_exact_nt<ET> , CGAL::Tag_true > { // Every type ET of Lazy_exact_nt<ET> has to be real embeddable. BOOST_STATIC_ASSERT((::boost::is_same< typename Real_embeddable_traits< ET > ::Is_real_embeddable, Tag_true >::value)); public: typedef Lazy_exact_nt<ET> Type; class Abs : public std::unary_function< Type, Type > { public: Type operator()( const Type& a ) const { CGAL_PROFILER(std::string("calls to : ") + std::string(CGAL_PRETTY_FUNCTION)); return new Lazy_exact_Abs<ET>(a); } }; class Sgn : public std::unary_function< Type, ::CGAL::Sign > { public: ::CGAL::Sign operator()( const Type& a ) const { CGAL_BRANCH_PROFILER(std::string(" failures/calls to : ") + std::string(CGAL_PRETTY_FUNCTION), tmp); Uncertain< ::CGAL::Sign> res = CGAL_NTS sign(a.approx()); if (is_certain(res)) return get_certain(res); CGAL_BRANCH_PROFILER_BRANCH(tmp); return CGAL_NTS sign(a.exact()); } }; class Compare : public std::binary_function< Type, Type, Comparison_result > { public: Comparison_result operator()( const Type& a, const Type& b ) const { CGAL_BRANCH_PROFILER(std::string(" failures/calls to : ") + std::string(CGAL_PRETTY_FUNCTION), tmp); if (a.identical(b)) return EQUAL; Uncertain<Comparison_result> res = CGAL_NTS compare(a.approx(), b.approx()); if (is_certain(res)) return get_certain(res); CGAL_BRANCH_PROFILER_BRANCH(tmp); return CGAL_NTS compare(a.exact(), b.exact()); } CGAL_IMPLICIT_INTEROPERABLE_BINARY_OPERATOR_WITH_RT( Type, Comparison_result ) }; class To_double : public std::unary_function< Type, double > { public: double operator()( const Type& a ) const { CGAL_BRANCH_PROFILER(std::string(" failures/calls to : ") + std::string(CGAL_PRETTY_FUNCTION), tmp); const Interval_nt<false>& app = a.approx(); double r; if (fit_in_double(app, r)) return r; // If it's precise enough, then OK. if (has_smaller_relative_precision(app, Lazy_exact_nt<ET>::get_relative_precision_of_to_double())) return CGAL_NTS to_double(app); CGAL_BRANCH_PROFILER_BRANCH(tmp); // Otherwise we trigger exact computation first, // which will refine the approximation. a.exact(); return CGAL_NTS to_double(a.approx()); } }; class To_interval : public std::unary_function< Type, std::pair< double, double > > { public: std::pair<double, double> operator()( const Type& a ) const { CGAL_PROFILER(std::string("calls to : ") + std::string(CGAL_PRETTY_FUNCTION)); return a.approx().pair(); } }; class Is_finite : public std::unary_function< Type, bool > { public: bool operator()( const Type& x ) const { return CGAL_NTS is_finite(x.approx()) || CGAL_NTS is_finite(x.exact()); } }; }; template <class ET1, class ET2, class F> class Lazy_exact_nt_coercion_traits_base { public: typedef Tag_false Are_explicit_interoperable; typedef Tag_false Are_implicit_interoperable; //typedef Null_type Type typedef Null_functor Cast; }; template <class ET1, class ET2> class Lazy_exact_nt_coercion_traits_base < Lazy_exact_nt<ET1>, Lazy_exact_nt<ET2>, Tag_true > { typedef Coercion_traits<ET1,ET2> CT; typedef Lazy_exact_nt<ET1> A; typedef Lazy_exact_nt<ET2> B; public: typedef Lazy_exact_nt<typename CT::Type> Type; typedef typename CT::Are_implicit_interoperable Are_explicit_interoperable; typedef typename CT::Are_implicit_interoperable Are_implicit_interoperable; class Cast{ private: template <class T> Type cast(const T& x) const{ return Type(x); } Type cast(const Type& x) const{ return x; } public: typedef Type result_type; Type operator()(const A& x) const { return cast(x);} Type operator()(const B& x) const { return cast(x);} }; }; CGAL_DEFINE_COERCION_TRAITS_FOR_SELF_TEM(Lazy_exact_nt<ET>, class ET) template<class ET1, class ET2 > struct Coercion_traits< Lazy_exact_nt<ET1>, Lazy_exact_nt<ET2> > :public Lazy_exact_nt_coercion_traits_base <Lazy_exact_nt<ET1>, Lazy_exact_nt<ET2>, typename Coercion_traits<ET1,ET2>::Are_implicit_interoperable>{}; #define CGAL_COERCION_TRAITS_LAZY_EXACT(NTX) \ template<class ET> \ struct Coercion_traits< NTX, Lazy_exact_nt<ET> >{ \ private: \ typedef Coercion_traits<NTX,ET> CT; \ typedef Lazy_exact_nt<ET> NT; \ public: \ typedef typename CT::Are_explicit_interoperable \ Are_explicit_interoperable; \ typedef typename CT::Are_implicit_interoperable \ Are_implicit_interoperable; \ private: \ static const bool interoperable \ =boost::is_same< Are_implicit_interoperable, Tag_false>::value; \ public: \ typedef typename boost::mpl::if_c <interoperable,Null_tag,NT> \ ::type Type; \ typedef typename boost::mpl::if_c <interoperable, Null_functor, \ INTERN_CT::Cast_from_to<NTX,NT> >::type Cast; \ }; \ \ template<class ET> \ struct Coercion_traits< Lazy_exact_nt<ET>, NTX > \ :public Coercion_traits<NTX, Lazy_exact_nt<ET> >{}; \ CGAL_COERCION_TRAITS_LAZY_EXACT(int) CGAL_COERCION_TRAITS_LAZY_EXACT(short) CGAL_COERCION_TRAITS_LAZY_EXACT(double) CGAL_COERCION_TRAITS_LAZY_EXACT(float) #undef CGAL_COERCION_TRAITS_LAZY_EXACT namespace INTERN_LAZY_EXACT_NT { template < typename NT, typename TAG > class Fraction_traits_base; template < class ET > class Fraction_traits_base <Lazy_exact_nt<ET> , CGAL::Tag_false> : public Fraction_traits<ET> { public: typedef Lazy_exact_nt<ET> Type; }; template < class ET > class Fraction_traits_base <Lazy_exact_nt<ET> , CGAL::Tag_true>{ typedef Fraction_traits<ET> ETT; typedef typename ETT::Numerator_type ET_numerator; typedef typename ETT::Denominator_type ET_denominator; public: typedef Lazy_exact_nt<ET> Type; typedef Tag_true Is_fraction; typedef Lazy_exact_nt<ET_numerator> Numerator_type; typedef Lazy_exact_nt<ET_denominator> Denominator_type; struct Common_factor : std::binary_function<Denominator_type,Denominator_type,Denominator_type>{ Denominator_type operator()(const Denominator_type& a, const Denominator_type& b) const { typename ETT::Common_factor common_factor; return Denominator_type(common_factor(a.exact(),b.exact())); } }; struct Compose : std::binary_function<Type,Numerator_type,Denominator_type>{ Type operator()(const Numerator_type& n, const Denominator_type& d) const { typename ETT::Compose compose; return Type(compose(n.exact(),d.exact())); } }; struct Decompose { typedef void result_type; typedef Type first_argument_type; typedef Numerator_type second_argument_type; typedef Denominator_type third_argument_type; void operator()(const Type& f, Numerator_type& n, Denominator_type& d) const { typename ETT::Decompose decompose; ET_numerator nn; ET_denominator dd; decompose(f.exact(),nn,dd); n = Numerator_type(nn); d = Denominator_type(dd); } }; }; } // namespace INTERN_LAZY_EXACT_NT template < class ET > class Fraction_traits< Lazy_exact_nt< ET > > :public INTERN_LAZY_EXACT_NT::Fraction_traits_base<Lazy_exact_nt<ET>, typename Fraction_traits<ET>::Is_fraction> {}; template < class ET > struct Min <Lazy_exact_nt<ET> > : public std::binary_function<Lazy_exact_nt<ET>,Lazy_exact_nt<ET>,Lazy_exact_nt<ET> > { Lazy_exact_nt<ET> operator()( const Lazy_exact_nt<ET>& x, const Lazy_exact_nt<ET>& y) const { CGAL_PROFILER(std::string("calls to : ") + std::string(CGAL_PRETTY_FUNCTION)); return new Lazy_exact_Min<ET>(x, y); } }; template < class ET > struct Max <Lazy_exact_nt<ET> > : public std::binary_function<Lazy_exact_nt<ET>,Lazy_exact_nt<ET>,Lazy_exact_nt<ET> > { Lazy_exact_nt<ET> operator()( const Lazy_exact_nt<ET>& x, const Lazy_exact_nt<ET>& y) const { CGAL_PROFILER(std::string("calls to : ") + std::string(CGAL_PRETTY_FUNCTION)); return new Lazy_exact_Max<ET>(x, y); } }; template<typename ET> inline Lazy_exact_nt<ET> min BOOST_PREVENT_MACRO_SUBSTITUTION( const Lazy_exact_nt<ET> & x, const Lazy_exact_nt<ET> & y){ return CGAL::Min<Lazy_exact_nt<ET> > ()(x,y); } template<typename ET> inline Lazy_exact_nt<ET> max BOOST_PREVENT_MACRO_SUBSTITUTION( const Lazy_exact_nt<ET> & x, const Lazy_exact_nt<ET> & y){ return CGAL::Max<Lazy_exact_nt<ET> > ()(x,y); } template <typename ET> std::ostream & operator<< (std::ostream & os, const Lazy_exact_nt<ET> & a) { return os << CGAL_NTS to_double(a); } template <typename ET> std::istream & operator>> (std::istream & is, Lazy_exact_nt<ET> & a) { ET e; is >> e; if (is) a = e; return is; } template< class ET > class Is_valid< Lazy_exact_nt<ET> > : public std::unary_function< Lazy_exact_nt<ET>, bool > { public : bool operator()( const Lazy_exact_nt<ET>& x ) const { return is_valid(x.approx()); } }; template < typename ET > struct NT_converter < Lazy_exact_nt<ET>, ET > { const ET& operator()(const Lazy_exact_nt<ET> &a) const { return a.exact(); } }; namespace internal { // Returns true if the value is representable by a double and to_double() // would return it. False means "don't know" (the exact number type is not // queried). template < typename ET > inline bool fit_in_double(const Lazy_exact_nt<ET>& l, double& r) { return fit_in_double(l.approx(), r); } } // namespace internal // We create a type of new node in Lazy_exact_nt's DAG // for the make_root_of_2() operation. template <typename ET > struct Lazy_exact_ro2 : public Lazy_exact_nt_rep< typename Root_of_traits<ET>::RootOf_2 > { typedef typename Root_of_traits<ET>::RootOf_2 RO2; typedef Lazy_exact_nt_rep<RO2> Base; typedef typename Base::AT::Protector P; mutable Lazy_exact_nt<ET> op1, op2, op3; bool smaller; bool old_rep;//if the rep=true then representation with polynomial coeff, else alpha, beta, gamma Lazy_exact_ro2 (const Lazy_exact_nt<ET> &a, const Lazy_exact_nt<ET> &b, const Lazy_exact_nt<ET> &c, bool s) : Base((P(), make_root_of_2(a.approx(), b.approx(), c.approx(), s))), op1(a), op2(b), op3(c), smaller(s), old_rep(true) {} Lazy_exact_ro2 (const Lazy_exact_nt<ET> &a, const Lazy_exact_nt<ET> &b, const Lazy_exact_nt<ET> &c) : Base((P(), make_root_of_2(a.approx(), b.approx(), c.approx()))), op1(a), op2(b), op3(c), smaller(true), old_rep(false) {} void update_exact() const { if (old_rep) this->et = new RO2(make_root_of_2(op1.exact(), op2.exact(), op3.exact(), smaller)); else this->et = new RO2(make_root_of_2(op1.exact(), op2.exact(), op3.exact())); if (!this->approx().is_point()) this->at = to_interval(*(this->et)); this->prune_dag(); } void prune_dag() const { op1 = op2 = op3 = Lazy_exact_nt<ET>(); } }; template <typename NT > struct Root_of_traits< Lazy_exact_nt < NT > > { private: typedef Root_of_traits<NT> T; public: typedef Root_of_traits< Lazy_exact_nt < NT > > Base; typedef Lazy_exact_nt< typename T::RootOf_1 > RootOf_1; typedef Lazy_exact_nt< typename T::RootOf_2 > RootOf_2; typedef RootOf_2 Root_of_2; typedef RootOf_1 Root_of_1; struct Make_root_of_2{ typedef RootOf_2 result_type; Root_of_2 operator()(const Lazy_exact_nt<NT>& a, const Lazy_exact_nt<NT>& b, const Lazy_exact_nt<NT>& c) const{ return new Lazy_exact_ro2<NT>(a, b, c); }; RootOf_2 operator()(const Lazy_exact_nt<NT>& a, const Lazy_exact_nt<NT>& b, const Lazy_exact_nt<NT>& c, bool smaller) const{ return new Lazy_exact_ro2<NT>(a, b, c, smaller); }; }; }; //these two functions for test suite requirement template < typename RT > typename CGAL::Root_of_traits<CGAL::Lazy_exact_nt<RT> >::RootOf_2 make_sqrt(const CGAL::Lazy_exact_nt< RT> & r) { typedef Lazy_exact_nt< RT> TT; CGAL_assertion(r >= 0); if(CGAL_NTS is_zero(r)) return make_root_of_2((TT) 1,(TT) 0,(TT) 0); return make_root_of_2((TT) 1,(TT) 0,-r,false); } template < typename RT > void print(std::ostream &os, const CGAL::Lazy_exact_nt< Root_of_2<RT> > &r) { print(os,r.exact()); } namespace INTERN_LAZY_EXACT_NT { template< typename ET , typename Tag> class Modular_traits_base{ public: typedef Lazy_exact_nt<ET> NT; typedef ::CGAL::Tag_false Is_modularizable; typedef ::CGAL::Null_functor Residue_type; typedef ::CGAL::Null_functor Modular_image; typedef ::CGAL::Null_functor Modular_image_representative; }; template< typename ET > class Modular_traits_base<ET, Tag_true>{ typedef Modular_traits<ET> MT_ET; public: typedef Lazy_exact_nt<ET> NT; typedef CGAL::Tag_true Is_modularizable; typedef typename MT_ET::Residue_type Residue_type; struct Modular_image{ Residue_type operator()(const NT& a){ typename MT_ET::Modular_image modular_image; return modular_image(a.exact()); } }; struct Modular_image_representative{ NT operator()(const Residue_type& x){ typename MT_ET::Modular_image_representative modular_image_representative; return NT(modular_image_representative(x)); } }; }; } // namespace INTERN_LAZY_EXACT_NT template < typename ET > class Modular_traits<Lazy_exact_nt<ET> > :public INTERN_LAZY_EXACT_NT::Modular_traits_base <ET,typename Modular_traits<ET>::Is_modularizable>{}; #undef CGAL_double #undef CGAL_int #undef CGAL_To_interval } //namespace CGAL #endif // CGAL_LAZY_EXACT_NT_H
- [cgal-discuss] Compilation error (bug?): call of overloaded ‘fit_in_double(const CGAL::L azy_exact_nt<CGAL::Gmpq>&, double&)’ is amb iguous, maag3377, 01/12/2011
- Re: [cgal-discuss] Compilation error (bug?): c all of overloaded ‘fit_in_double(const CGAL ::Lazy_exact_nt<CGAL::Gmpq>&, double&)’ is ambiguous, Sebastien Loriot (GeometryFactory), 01/12/2011
