cgal-discuss - Re: [cgal-discuss] Re: compiling CGAL in windows
  • To:
  • Subject: Re: [cgal-discuss] Re: compiling CGAL in windows
  • Date: Wed, 12 Jan 2011 10:15:17 +0100
Hi,
Usually, the error "The C compiler XXX is not able to compile a simple test
program" means that cmake does not have the rights to write in the folder.
Please give read/right permissions to C:/Program Files (x86)/CGAL-3.7 and its
sub-folders.
Best regards,
Laurent Saboret
Le 12/01/2011 07:33, drorsh a écrit :
Hello,
First of all, thanks for all the help. Running cmake-gui instead of cmake
did not help, but running as administrator seems to get me a bit further in
the compilation process (I ran the visual studio 2008 command prompt as
administrator, and then tried both "cmake ." and "cmake-gui .").
The error I get in both cases is the following:
-- Check for working C compiler using: Visual Studio 9 2008 Win64
-- Check for working C compiler using: Visual Studio 9 2008 Win64 -- broken
CMake Error at C:/Program Files (x86)/CMake
2.8/share/cmake-2.8/Modules/CMakeTes
tCCompiler.cmake:52 (MESSAGE):
The C compiler "C:/Program Files (x86)/Microsoft Visual Studio
9.0/VC/bin/cl.exe" is not able to compile a simple test program.
It fails with the following output:
Change Dir: C:/Program Files (x86)/CGAL-3.7/CMakeFiles/CMakeTmp
Run Build Command:C:\PROGRA~2\MICROS~2.0\Common7\IDE\VCExpress.exe
CMAKE_TRY_COMPILE.sln /build Debug /project cmTryCompileExec
Microsoft (R) Visual C++ Express Edition Version 9.0.30729.1.
Copyright (C) Microsoft Corp 2007. All rights reserved.
The project consists entirely of configurations that require support for
platforms which are not installed on this machine. The project cannot be
loaded.
loaded.
Invalid project
Use:
vcexpress [solutionfile | projectfile | anyfile.ext] [switches]
The first argument for devenv is usually a solution file or project file.
You can also use any other file as the first argument if you want to have
the
file open automatically in an editor. When you enter a project file, the
IDE
looks for an .sln file with the same base name as the project file in the
parent directory for the project file. If no such .sln file exists, then
the
IDE looks for a single .sln file that references the project. If no such
single
.sln file exists, then the IDE creates an unsaved solution with a default
.sln
file name that has the same base name as the project file.
Command line builds:
devenv solutionfile.sln /build [ solutionconfig ] [ /project
projectnameorfile [ /projectconfig name ] ]
Available command line switches:
/Log Logs IDE activity to the specified file for troubleshooting.
/ResetSettings Restores the IDE's default settings, optionally
resets to
the specified VSSettings file.
/SafeMode Launches the IDE in safe mode loading minimal windows.
Product-specific switches:
/debugexe Open the specified executable to be debugged. The
remainder of the command line is passed to this
executable as its arguments.
/useenv Use PATH, INCLUDE, LIBPATH, and LIB environment
variables
instead of IDE paths for VC++ builds.
To attach the debugger from the command line, use:
VsJITDebugger.exe -p<pid>
CMake will not be able to correctly generate this project.
Call Stack (most recent call first):
CMakeLists.txt:6 (project)
-- Configuring incomplete, errors occurred!
Again, any help would be appreciated.
Thanks,
Dror
