- To:
- Subject: Re: [cgal-discuss] Half-edge representation, CGAL vs OpenMesh
- Date: Thu, 13 Jan 2011 09:21:50 +0100
Nicholas Mario Wardhana wrote:
On 13 January 2011 15:01, Sebastien Loriot (GeometryFactory)The Polyhedron_3 class of CGAL documented here:
wrote:
I am quite surprised by your answer. What are the limitation of the
existing data structures?
Hi Sebastien,
What we abandon is the idea of using half-edge representation.
Previously we were about to implement a method to compute the
intersections of some polyhedra, which are represented by their
half-edges. However, after our recent internal discussion, it turned
out that our previous method was too complicated, so we are trying
different approach. So far face-vertex (FV) representation is enough
for this purpose, and we are not sure whether either CGAL or OpenMesh
directly supports it. For CGAL, we can't find a class like polygon in
3D space to represent the face, and I suppose the face classes in both
CGAL and OpenMesh (HalfedgeDS<Traits,Items,Alloc>::Face in CGAL and
OpenMesh::PolyMeshT<Kernel> in OpenMesh, although I am not really sure
about the latter) are quite closely related to half-edge structure
(please correct me if I am wrong), so currently we develop our simple
FV data structure.
My apology if I did not make myself clearly enough in the previous
e-mail, and thank you.
Best regards,
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Polyhedron_ref/Class_Polyhedron_3.html
provides iterator over vertices,facets and halfedges.
Given a facet, you can use Halfedge_around_facet_const_circulator to get the vertices of a face (using the incident vertex to each halfedge).
See: http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Polyhedron_ref/Class_Polyhedron_3-Traits---Facet.html
I don't want to prevent you from implementing your own data structure if
you think it will be more efficient but you may save time by using an
existing one (in particular because many additional functionalities are available in CGAL).
S.
- [cgal-discuss] Half-edge representation, CGAL vs OpenMesh, Nicholas Mario Wardhana, 01/05/2011
- [cgal-discuss] Re: Half-edge representation, CGAL vs OpenMesh, Nicholas Mario Wardhana, 01/05/2011
- Re: [cgal-discuss] Half-edge representation, CGAL vs OpenMesh, Pierre Alliez, 01/12/2011
- Re: [cgal-discuss] Half-edge representation, CGAL vs OpenMesh, Nicholas Mario Wardhana, 01/13/2011
- Re: [cgal-discuss] Half-edge representation, CGAL vs OpenMesh, Sebastien Loriot (GeometryFactory), 01/13/2011
