cgal-discuss - Re: [cgal-discuss] Memory issue with openSUSE 11.3, exact kernel, adding points/vectors
  • To:
  • Subject: Re: [cgal-discuss] Memory issue with openSUSE 11.3, exact kernel, adding points/vectors
  • Date: Tue, 18 Jan 2011 08:04:56 +0100
Francois Berenger wrote:
Hello,
Sorry for the maybe stupid question: why not use valgrind to locate the memory leak automatically?
See this thread:
http://cgal-discuss.949826.n4.nabble.com/Valgrind-td2308953.html#a2308963
S.
Regards,
F.
Graham Macpherson wrote:
Hi Sebastien,
Thanks for the reply.
I've checked and I do see the linear memory increase with openSUSE and not with
Ubuntu; the logs I attached to my email are valid.
Is it worth investigating if gcc 4.4 vs 4.5 makes a difference?
Regards,
Graham
On Monday 17 January 2011 08:40:52 Sebastien Loriot (GeometryFactory) wrote:
There is no memory leak in your code.
Behind the Exact_predicates_exact_constructions_kernel, there are
*a multi-precision number type (for example Gmpq if GMP is available)
*filtering mechanism on constructed objects (such as points)
In your for loop, you are iteratively summing to your points a vector.
Both implementation details are responsible for the memory increase:
*The precision needed by the number type to exactly do the sums
requires more precision, thus more space. Running you code with
CGAL::Simple_cartesian<CGAL::Gmpq>, you will observe an increase in
memory usage, but not at each iteration (only when precision of numbers
is increased).
*the filtering mechanism maintain a DAG of the cascaded constructions.
Each sum create a note in the DAG. This is the real cause of the memory
usage increase in your case.
However, I am surprised that you do not observe the memory consumption
increase on Ubuntu.
Can you please check again to confirm whether there is a problem?
S.
Hello all,
I've found a strange memory problem that I've reproduced in the attached code.
I'm taking the vertices of a Delaunay tessellation, calculating a displacement
for them, clearing the tessellation, then reinserting the displaced vertices.
When I run this, the memory use by the process increases linearly with each
iteration, which is wrong, it should be essentially constant, however:
+ The problem doesn't occur with option A in the attached, only with option B,
i.e. when adding a Vector_3 to the point;
+ The problem doesn't occur using
Exact_predicates_inexact_constructions_kernel, only with
Exact_predicates_exact_constructions_kernel;
+ It doesn't appear on all operating systems - it appears on openSUSE 11.3, but
not on Ubuntu 10.04.
Also attached are two log files showing the contrasting behaviour on the two
operating systems with the code the same.
I've tried on openSUSE 11.3 with gcc 4.5.0 (system compiler) and gcc 4.5.2,
boost versions 1.40.0, 1.42.0 (system) and 1.45.0, and with CGAL 3.5.1 and CGAL
3.7, and they all essentially do the same thing.
On Ubuntu I'm using CGAL 3.7, gcc 4.4.3 (system compiler) and boost 1.40.0
(system).
Note, the memInfo class is one that's part of other libraries I'm using, so it
won't compile for you, it's only there to show how the output was generated.
Assuming that the addition operation in option B is legitimate, then this looks
like a bug in a library. Any suggestions for how to get to the bottom of it?
Best regards,
Graham
Graham Macpherson
OpenCFD Ltd.
www.openfoam.com
+44 (0)118 9471030
9 Albert Road
Caversham
Reading RG4 7AN
