cgal-discuss - Re: [cgal-discuss] Memory issue with openSUSE 11.3, exact kernel, adding points/vectors
  • To:
  • Subject: Re: [cgal-discuss] Memory issue with openSUSE 11.3, exact kernel, adding points/vectors
  • Date: Mon, 17 Jan 2011 11:00:52 +0000
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=from:organization:to:subject:date:user-agent:references:in-reply-to :mime-version:content-type:content-transfer-encoding:message-id; b=ogIt6TAQeQO8U9ao1xEWNQk5LB6XXcGnPSmwm2RvX245p793vRRAB8UcQaSRyvhTaJ /DvmIS5L2oLNsdGsJ3QAqzxSYxFJwuBaN2gCDaCg33dFcMHvSG42Ym57uEYBtw+bMSrS ILUhUhmAuMgI114P4FMOFeCY7wPlFUgMQoGE8=
  • Organization: OpenCFD Ltd.
Hi Sebastien,
Thanks for the reply.
I've checked and I do see the linear memory increase with openSUSE and not
with
Ubuntu; the logs I attached to my email are valid.
Is it worth investigating if gcc 4.4 vs 4.5 makes a difference?
Regards,
Graham
On Monday 17 January 2011 08:40:52 Sebastien Loriot (GeometryFactory) wrote:
> There is no memory leak in your code.
> Behind the Exact_predicates_exact_constructions_kernel, there are
> *a multi-precision number type (for example Gmpq if GMP is available)
> *filtering mechanism on constructed objects (such as points)
> In your for loop, you are iteratively summing to your points a vector.
> Both implementation details are responsible for the memory increase:
> *The precision needed by the number type to exactly do the sums
> requires more precision, thus more space. Running you code with
> CGAL::Simple_cartesian<CGAL::Gmpq>, you will observe an increase in
> memory usage, but not at each iteration (only when precision of numbers
> is increased).
> *the filtering mechanism maintain a DAG of the cascaded constructions.
> Each sum create a note in the DAG. This is the real cause of the memory
> usage increase in your case.
> However, I am surprised that you do not observe the memory consumption
> increase on Ubuntu.
> Can you please check again to confirm whether there is a problem?
> S.
> Graham Macpherson wrote:
> > Hello all,
> > I've found a strange memory problem that I've reproduced in the attached
> > code.
> > I'm taking the vertices of a Delaunay tessellation, calculating a
> > displacement
> > for them, clearing the tessellation, then reinserting the displaced
> > vertices.
> > When I run this, the memory use by the process increases linearly with
> > each
> > iteration, which is wrong, it should be essentially constant, however:
> > + The problem doesn't occur with option A in the attached, only with
> > option B,
> > i.e. when adding a Vector_3 to the point;
> > + The problem doesn't occur using
> > Exact_predicates_inexact_constructions_kernel, only with
> > Exact_predicates_exact_constructions_kernel;
> > + It doesn't appear on all operating systems - it appears on openSUSE
> > 11.3, but
> > not on Ubuntu 10.04.
> > Also attached are two log files showing the contrasting behaviour on the
> > two
> > operating systems with the code the same.
> > I've tried on openSUSE 11.3 with gcc 4.5.0 (system compiler) and gcc
> > 4.5.2,
> > boost versions 1.40.0, 1.42.0 (system) and 1.45.0, and with CGAL 3.5.1
> > and CGAL
> > 3.7, and they all essentially do the same thing.
> > On Ubuntu I'm using CGAL 3.7, gcc 4.4.3 (system compiler) and boost 1.40.0
> > (system).
> > Note, the memInfo class is one that's part of other libraries I'm using,
> > so it
> > won't compile for you, it's only there to show how the output was
> > generated.
> > Assuming that the addition operation in option B is legitimate, then this
> > looks
> > like a bug in a library. Any suggestions for how to get to the bottom of
> > it?
> > Best regards,
> > Graham
> > Graham Macpherson
> > OpenCFD Ltd.
> > www.openfoam.com
> > +44 (0)118 9471030
> > 9 Albert Road
> > Caversham
> > Reading RG4 7AN
