- To:
- Subject: [cgal-discuss] Proper way to convert between Plane_3<Kernel>
- Date: Thu, 20 Jan 2011 23:15:23 -0500
Hi All,
I'm trying to convert from CGAL::Plane_3 with two different kernels. Specifically, I'd like to convert from:
Plane_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > >
to
CGAL::Plane_3<CGAL::Simple_cartesian<double> >
But I can't quite figure out how to do that from the manual or the code other than manually selecting points from the the first plane and construct a plane of the second kernel with these points... Is there a better way of doing this?
Any advice would be welcomed...
Thanks,
Frankie
- [cgal-discuss] minkowski sum issue, tofa, 01/20/2011
- [cgal-discuss] Proper way to convert between Plane_3<Kernel>, Frankie Li, 01/21/2011
- Re: [cgal-discuss] Proper way to convert between Plane_3<Kernel>, Sebastien Loriot (GeometryFactory), 01/24/2011
- Re: [cgal-discuss] Proper way to convert between Plane_3<Kernel>, Frankie Li, 01/24/2011
- Re: [cgal-discuss] minkowski sum issue, efif, 01/22/2011
