- To:
- Subject: Re: [cgal-discuss] Proper way to convert between Plane_3<Kernel>
- Date: Mon, 24 Jan 2011 09:52:51 -0500
Thanks!
Frankie
Sebastien Loriot (GeometryFactory) wrote:
Frankie Li wrote:
Hi All,Have a look here:
I'm trying to convert from CGAL::Plane_3 with two different kernels. Specifically, I'd like to convert from:
Plane_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > >
to
CGAL::Plane_3<CGAL::Simple_cartesian<double> >
But I can't quite figure out how to do that from the manual or the code other than manually selecting points from the the first plane and construct a plane of the second kernel with these points... Is there a better way of doing this?
Any advice would be welcomed...
Thanks,
Frankie
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Kernel_23_ref/Class_Cartesian_converter.html
You can use it like this:
typedef CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > K1;
typedef CGAL::Simple_cartesian<double> K2;
CGAL::Cartesian_converter<K1,K2> converter;
K1::Plane_3 p1;
K2::Plane_3 p2 = converter(p1);
S.
- [cgal-discuss] minkowski sum issue, tofa, 01/20/2011
- [cgal-discuss] Proper way to convert between Plane_3<Kernel>, Frankie Li, 01/21/2011
- Re: [cgal-discuss] Proper way to convert between Plane_3<Kernel>, Sebastien Loriot (GeometryFactory), 01/24/2011
- Re: [cgal-discuss] Proper way to convert between Plane_3<Kernel>, Frankie Li, 01/24/2011
- Re: [cgal-discuss] minkowski sum issue, efif, 01/22/2011
