- To:
- Subject: Re: [cgal-discuss] CGAL assertions using Minkowski_sum_3
- Date: Mon, 24 Jan 2011 09:10:47 +0100
I add a quick look but did not have time to finish my investigations.
Can you try with CGAL::Simple_cartesian<CGAL::Gmpq> as Kernel and tell
us whether you also observe the same problems?
S.
J.L.M. wrote:
I was wondering if any progress has been made to fix the boundary function for Nef_polyhedron_3. I am using this code in a thesis, and I am finding that I can not avoid the assertion in the Minkowski_sum_3 if I use a non-convex polyhedron. Limiting my input to convex polyhedra greatly reduces the utility of my implementation, and my experiment depends on non-convex polyhedra.
Thank you for your time.
Jason M'Sadoques
On 12/27/2010 04:32 PM, J.L.M. wrote:
Sebastien,
Thank you for your reply. I have been on holiday, or I would have
responded sooner. I hope you will be able to provide a fix to the
boundary function, as this is essential to my research. If there is
anything I can do to help, please let me know.
Here are a few responses to your statements. The call to boundary is
necessary for my work. What I am computing is the feasible region that
contains all points in which the object can be placed and be wholly
contained in the container (stored in result). If you would like, I have
a paper I can provide to you that shows how this works.
Second, I am wondering about your statement that I need to make a copy
of container. I see that the minkowski_sum_3 modifies the input, and in
my example code the input is container_boundary, and object.
container_boundary should be a copy of container (well just the boundary
of course).
You are correct that the result is empty in this example. The correct
algorithm uses the interior of the object (actually the inverted
interior) in the Minkowski sum. I removed that part while simplifying
the code to one that shows the problem.
Thank you for pointing out the non-standard OFF files. I am creating my
shapes in Blender, and I have to post-process them. First, Blender gives
me coordinates that are something like 1.00001 or 0.99999, and I need
them to be exact whole numbers for accurate computations. Also, Blender
has Z increase up, and Y increase into the scene, which is different
than I am used to with OpenGL, so I swapped those coordinates. It must
be in my swapping of those that I have switched the orientation of the
facets.
Thank you again for your time.
On 12/20/2010 08:26 AM, Sebastien Loriot (GeometryFactory) wrote:
J.L.M. wrote:
I have been writing some programs that use the Nef_polyhedron_3 andIt seems their is a problem in boundary function.
Minkowski_sum_3 portions of the CGAL library. I have discovered a
number of assertions with various input shapes. The attached backtrace
shows one example problem. I have also attached a small example
program, and the input shapes. The l-shape is shown in the attached
jpeg file.
This problem shows up in both CGAL 3.7 and 3.6.1. I am using GCC 4.5.1
on Arch Linux with kernel version 2.6.36.
I think this is a bug, since it does not occur with other input
shapes. I would be very grateful if someone can help me fix it since
the Minkowski_sum_3 is essential to my research.
Jason M'Sadoques
If I replace:
Nef_polyhedron_3 container_boundary(container.boundary());
by
Nef_polyhedron_3 container_boundary(container);
Your program runs fine (with your data, the call to boundary is
superfluous).
Note that as you are then reusing "container", you need to make a copy
of it
(see
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Minkowski_sum_3/Chapter_main.html)
Note also that the difference you are computing will be empty as the
Minkowski sum contains "container".
Finally, note that facets of your cube are clockwise oriented while the
usual convention is to use counterclockwise oriented faces in off files.
I'll try to find a fix to boundary function and will post it here.
S.
- Re: [cgal-discuss] CGAL assertions using Minkowski_sum_3, J.L.M., 01/23/2011
- Re: [cgal-discuss] CGAL assertions using Minkowski_sum_3, Sebastien Loriot (GeometryFactory), 01/24/2011
