cgal-discuss - Re: [cgal-discuss] point location/interpolation on a 2d mesh
  • To:
  • Subject: Re: [cgal-discuss] point location/interpolation on a 2d mesh
  • Date: Mon, 24 Jan 2011 09:31:57 +0100
Hansjoerg Seybold wrote:
Hello,
Hello I would like to calculate interpolated values from vertices on a 2d mesh.
My problem is as follows:
- I have a mesh given by vertices and constraints (i know the boundary and the partitioning of the space (holes) )
- With this information i would like to create a cgal mesh to perform interpolation operations of lets say the velocity field stored in the
vertices.
I saw the cgal interpolation page and the point location page for the triangulation.
Is it also possible to use the triangulation hierarchy on a mesh for efficient point location.
I need a mesh to determine what is inside and what is outside as the domain has holes or is there a simpler way to perform interpolation/and determining inside/outside like in the mesh case.
Thank you very much
hj
From what I understand, you have a surface mesh with hole that you computed (not using CGAL surface mesher) and you want:
1) determine whether a point is on your surface
2) use CGAL::surface_neighbor_coordinates_3 only on points detected on
your surface
For 1) using AABB_tree and closest_point_and_primitive might help
(http://www.cgal.org/Manual/latest/doc_html/cgal_manual/AABB_tree/Chapter_main.html#Section_62.6).
Using the triangulation hierarchy will be complicated as you first need
to have a your surface included into a 3D triangulation.
S.
