RE: [cgal-discuss] Distance between a point set and a point not in it or in another point set
- To: <>
- Subject: RE: [cgal-discuss] Distance between a point set and a point not in it or in another point set
- Date: Wed, 26 Jan 2011 17:16:17 +0100
Hi Sébastien,
Thank you very much for your quick reply.
> For your first question using k-nearest neighbor search with k=1 will
> make it (insert your points in the tree and make the query with your
> point). See example here:
> http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Spatial_searching/Chapter
> _main.html#Subsection_59.3.1
This is what I was looking for.
> For the second one, a naive method is to use the first method
> iteratively over all the points of one set and take the pair with
> smallest distance. If you have performance issues, probably filtering
> points with bbox should be more efficient.
I will explore that because I have indeed performance issues.
Thank you!
Best regards,
Philippe
- [cgal-discuss] Distance between a point set and a point not in it or in another point set, zaphod, 01/26/2011
- Re: [cgal-discuss] Distance between a point set and a point not in it or in another point set, Sebastien Loriot (GeometryFactory), 01/26/2011
- RE: [cgal-discuss] Distance between a point set and a point not in it or in another point set, Philippe GAMBRON, 01/26/2011
