Re: [cgal-discuss] Distance between a point set and a point not in it or in another point set
- To:
- Subject: Re: [cgal-discuss] Distance between a point set and a point not in it or in another point set
- Date: Wed, 26 Jan 2011 17:46:31 +0100
Philippe GAMBRON wrote:
Hi Sébastien,One idea is to use one kd-tree for each point set and to compare distances between bboxes (since it is bounding the distance between points contained).
Thank you very much for your quick reply.
For your first question using k-nearest neighbor search with k=1 will make it (insert your points in the tree and make the query with your
point). See example here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Spatial_searching/Chapter
_main.html#Subsection_59.3.1
This is what I was looking for.
For the second one, a naive method is to use the first method iteratively over all the points of one set and take the pair with
smallest distance. If you have performance issues, probably filtering
points with bbox should be more efficient.
The walk on nodes of a kd-tree is an advanced feature.
Doc of the tree (use root() method to get the first node):
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Spatial_searching_ref/Class_Kd_tree.html#Cross_link_anchor_1622
Doc of the node class:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Spatial_searching_ref/Class_Kd_tree_node.html#Cross_link_anchor_1623
S.
I will explore that because I have indeed performance issues.
Thank you!
Best regards,
Philippe
- [cgal-discuss] Distance between a point set and a point not in it or in another point set, zaphod, 01/26/2011
- Re: [cgal-discuss] Distance between a point set and a point not in it or in another point set, Sebastien Loriot (GeometryFactory), 01/26/2011
- RE: [cgal-discuss] Distance between a point set and a point not in it or in another point set, Philippe GAMBRON, 01/26/2011
