- To:
- Subject: [cgal-discuss] nearest points
- Date: Tue, 1 Feb 2011 18:29:36 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type; b=BrcD/FeP7AHJ+d5oVz5yIqJJtJTFcjbCJYC0oT4kYPTred4gzFJIJf3ufK1Ocd6dJC olu2bklJJx/ePp1w8BtxkJvbiDy0ytz+xpXEeTYhjgLsoWh59k+T9z/pwkR6752JLBY9 JETqXPXNdoRRDPgsa3542cShT2CQXPKiwtSoY=
Hi,
I am looking following example under examples/Point_set_2/nearest_neighborhood.cpp. I want to
assign some values to each points. After I found nearest points, I would like to reach
nearest points' values. I can do this through std::map, but I don't feel that it is the
right way.
As an example, you have temperature field over 2D domain (x,y). Each point
you have some temperature value such as (x,y,T). When I ask nearest
points around (x0,y0), I also want to get T values, in addition to (x,y)s , of nearest locations.
Could you help me out?
Thanks,
#include <CGAL/Point_set_2.h>
#include <list>
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Point_set_2<K>::Edge_iterator Edge_iterator;
typedef CGAL::Point_set_2<K>::Vertex_handle Vertex_handle;
typedef K::Point_2 Point_2;
CGAL::Point_set_2<K> PSet;
Point_2 ar1[5];
int main()
std::list<Point_2> Lr;
Point_2 p1(12,14);
Point_2 p2(-12,14);
Point_2 p3(2,11);
Point_2 p4(5,6);
Point_2 p5(6.7,3.8);
Point_2 p6(11,20);
Point_2 p7(-5,6);
Point_2 p8(12,0);
Point_2 p9(4,31);
Point_2 p10(-10,-10);
Lr.push_back(p1); Lr.push_back(p2); Lr.push_back(p3);
Lr.push_back(p4); Lr.push_back(p5); Lr.push_back(p6);
Lr.push_back(p7); Lr.push_back(p8); Lr.push_back(p9);
Lr.push_back(p10);
PSet.insert(Lr.begin(),Lr.end());
// init
ar1[0]=p4; ar1[1]=p5; ar1[2]=p3; ar1[3]=p7; ar1[4]=p8;
Point_2 actual(3.0,4.5);
// nearest neighbor ...
Vertex_handle v = PSet.nearest_neighbor(actual);
std::cout << "Nearest neighbor:" << v->point() << "\n";
// k nearest neighbors ...
std::list<Vertex_handle> L;
std::list<Vertex_handle>::const_iterator it;
PSet.nearest_neighbors(actual,7, std::back_inserter(L));
std::cout << "actual point: " << actual << "\n";
for (it=L.begin();it != L.end(); it++)
std::cout << (*it)->point() << " infor = " << (*it)->info() << "\n";
return 0;
B. Gazi YILDIRIM
- [cgal-discuss] nearest points, Battalgazi YILDIRIM, 02/02/2011
- Re: [cgal-discuss] nearest points, Sebastien Loriot (GeometryFactory), 02/02/2011
