- To:
- Subject: Re: [cgal-discuss] question regarding qt version
- Date: Wed, 9 Feb 2011 09:57:08 +0100
Le mercredi 09 février 2011 07:59:37, DanielYan a écrit :
> Hi Rineau,
> Thank you for making a response.
> It should be QT-4.7, not 3.7, right?
Right. I meant Qt-4.7.
> I opened the CGAL.sln generated by CMake and was trying to build the whole
> project. I'm using VS2005, with the operating system WindowsXP SP3. It
> doesn't make any difference after the line:
> Q_DECLARE_INTERFACE(QGraphicsItem, "com.trolltech.Qt.QGraphicsItem")
> added to <QtGui/qgraphicsitem.h>. The Error hint still get printed.
> So, could you point out where the things go wrong?
VS-2005 is not longer supported by CGAL-3.7, and is no longer tested in our
daily test process. It may be the reason. However, I doubt it is.
In the CMakeCache.txt file, what is the value of QT_INCLUDE_DIR and
QT_QTGUI_INCLUDE_DIR?
Please do not modify your Qt-4.7, otherwise there will be no way to
understand
what happened, and you may get more incomprehensible behaviors like the one
you have.
Laurent Rineau, PhD
- [cgal-discuss] question regarding qt version, DanielYan, 02/08/2011
- Re: [cgal-discuss] question regarding qt version, Laurent Rineau (GeometryFactory), 02/08/2011
- Re: [cgal-discuss] question regarding qt version, DanielYan, 02/09/2011
- Re: [cgal-discuss] question regarding qt version, Laurent Rineau (GeometryFactory), 02/09/2011
