cgal-discuss - Re: [cgal-discuss] question regarding qt version
  • To: <>
  • Subject: Re: [cgal-discuss] question regarding qt version
  • Date: Thu, 10 Feb 2011 00:39:26 +0800
  • Importance: Normal
Hi Laurent,
Will it help if I download the source code of QT4.7 and compile it myself?
Cuz before this, I simply downloaded qt-sdk-win-opensource-2010.05.exe.
Thank you for your time!
Yan.
Sent: Wednesday, February 09, 2011 4:57 PM
To:
> Le mercredi 09 février 2011 07:59:37, DanielYan a écrit :
>> Hi Rineau,
>> Thank you for making a response.
>> It should be QT-4.7, not 3.7, right?
> Right. I meant Qt-4.7.
>> I opened the CGAL.sln generated by CMake and was trying to build the whole
>> project. I'm using VS2005, with the operating system WindowsXP SP3. It
>> doesn't make any difference after the line:
>> Q_DECLARE_INTERFACE(QGraphicsItem, "com.trolltech.Qt.QGraphicsItem")
>> added to <QtGui/qgraphicsitem.h>. The Error hint still get printed.
>> So, could you point out where the things go wrong?
> VS-2005 is not longer supported by CGAL-3.7, and is no longer tested in our
> daily test process. It may be the reason. However, I doubt it is.
> In the CMakeCache.txt file, what is the value of QT_INCLUDE_DIR and
> QT_QTGUI_INCLUDE_DIR?
> Please do not modify your Qt-4.7, otherwise there will be no way to
> understand
> what happened, and you may get more incomprehensible behaviors like the one
> you have.
> Laurent Rineau, PhD
> Release Manager of the CGAL Project http://www.cgal.org/
> R&D Engineer at GeometryFactory http://www.geometryfactory.com/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
