cgal-discuss - Re: [cgal-discuss] interpolation on a mesh
  • To:
  • Subject: Re: [cgal-discuss] interpolation on a mesh
  • Date: Thu, 10 Feb 2011 14:37:19 +0100
Thanks for the nice pictures.
With this patched file, you should be able to run
natural_neighbor_coordinates_2 on a object of type
Constrained_Delaunay_triangulation_2.
I am not sure of what you will get near constrained edges.
S.
mturner wrote:
Hello,
We are using the CGAL libraries to help analyze surface motions of geological features on the Earth. The geometry of the features define the boundary and interior of specific surface regions.
Because our geographic regions are small, and to keep things simple for now,
we consider the positions and motions only in 2D, using coordinates of Latitude and Longitude.
Each geologic feature is defined by a basic geometry (point, line, or
polygon),
and each geometry contributes to either the boundary of the region, or the
interior.
Following the example code in Chapter 35 "2D Triangulations", we use the vertices from the feature geometry, to build a series of
triangulations:
- Delaunay Triangulation ( CGAL::Delaunay_triangulation_2<...> ),
- Constrained Triangulation (
CGAL::Constrained_Delaunay_triangulation_2<...> ),
- Mesh Triangulation ( CGAL::Delaunay_mesher_2<...> ).
We have posted images showing an example region,
with the various feature geometry components,
and the resulting triangulations here:
http://web.gps.caltech.edu/~mturner/cgal_post/
Figure 1 shows the basic feature data:
the boundary of the region is defined by intersections of five lines
(two red lines at the top, purple line on the right, red line at the bottom,
green line on left).
The Interior elements are defined by three points, three lines, and two
polygons inside that region.
Figure 2 shows the Delaunay Triangulation from that data in black,
including the convex hull triangles formed where the boundary is concave.
Figure 3 shows the Constrained Triangulation in gray.
Figure 4 shows the Mesh Triangulation in light green, with areas outside the total outer boundary un-meshed;
and areas inside the interior polygons un-meshed.
The interior holes were generated by adding seed points and calling the constrained mesher's set_seeds(...) function.
Then the Mesh was generated with a call to:
constrained_mesher->refine_mesh();
This aspect of using CGAL to create triangulations and meshes has been very successful for both test examples and real world data.
Now we would like to use the final meshes to perform interpolation.
We have measurements of surface velocity for the basic feature data,
and we would like to use a refined CGAL mesh to interpolate that velocity data for any given test point inside the region.
Following the example code in Chapter 68 "2D and Surface Function
Interpolation",
we have successfully used the interpolation functions on the Delaunay
Triangulation, using the functions such as:
CGAL::natural_neighbor_coordinates_2, CGAL::sibson_gradient_fitting, CGAL::Data_access, etc.
Figure 5 shows the measured velocity at the feature vertices with white
arrows, and the interpolated velocity at the sample test points with black arrows.
Unfortunately, interpolating with the Delaunay Triangulation allows for interpolation outside the region (as shown by the left black
arrow),
and inside the holes of the mesh (as shown inside).
We would like to use the Mesh Triangulation for interpolation, not only because it is more refined,
but also because the mesh is able to exclude, or 'mask out', the interior polygon areas and external concave areas.
However, I cannot find an example using a CGAL Mesh to interpolate.
Is there a way to connect the CGAL interpolation code with the mesh code?
It seems like there must be a way to utilize the refined mesh to perform interpolation, but I could not find a way to make it work...
Thanks for any help or guidance you can provide,
Mark Turner
California Institute of Technology
Division of Geological and Planetary Sciences, Mail Code 100-23
Pasadena, CA 91125
Phone: 626-395-4543
// Copyright (c) 1997  INRIA Sophia-Antipolis (France).
// All rights reserved.
// This file is part of CGAL (www.cgal.org); you may redistribute it under
// the terms of the Q Public License version 1.0.
// See the file LICENSE.QPL distributed with CGAL.
// Licensees holding a valid commercial license may use this file in
// accordance with the commercial license agreement provided with the software.
// This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE
// WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
// $URL: svn+ssh://scm.gforge.inria.fr/svn/cgal/branches/CGAL-3.7-branch/Triangulation_2/include/CGAL/Constrained_Delaunay_triangulation_2.h $
// $Id: Constrained_Delaunay_triangulation_2.h 57014 2010-06-23 13:29:04Z afabri $
// Author(s)     : Mariette Yvinec, Jean Daniel Boissonnat
#ifndef CGAL_CONSTRAINED_DELAUNAY_TRIANGULATION_2_H
#define CGAL_CONSTRAINED_DELAUNAY_TRIANGULATION_2_H
#include <CGAL/triangulation_assertions.h>
#include <CGAL/Constrained_triangulation_2.h>
namespace CGAL {
template <class Gt,
          class Tds = Triangulation_data_structure_2 <
                      Triangulation_vertex_base_2<Gt>,
		      Constrained_triangulation_face_base_2<Gt> >,
	  class Itag = No_intersection_tag >
class Constrained_Delaunay_triangulation_2
  : public  Constrained_triangulation_2<Gt, Tds, Itag>
public:
  typedef Constrained_triangulation_2<Gt,Tds,Itag>             Ctr;
  typedef Constrained_Delaunay_triangulation_2<Gt,Tds,Itag>    CDt;
  typedef typename Ctr::Geom_traits      Geom_traits;
  typedef typename Ctr::Intersection_tag Intersection_tag;
  typedef typename Ctr::Constraint    Constraint;
  typedef typename Ctr::Vertex_handle Vertex_handle;
  typedef typename Ctr::Face_handle   Face_handle;
  typedef typename Ctr::Edge          Edge;
  typedef typename Ctr::Finite_faces_iterator Finite_faces_iterator;
  typedef typename Ctr::Face_circulator       Face_circulator;
  typedef typename Ctr::size_type             size_type;
  typedef typename Ctr::Locate_type           Locate_type;
  typedef typename Ctr::List_edges List_edges;
  typedef typename Ctr::List_faces List_faces;
  typedef typename Ctr::List_vertices  List_vertices;
  typedef typename Ctr::List_constraints List_constraints;
  typedef typename Ctr::Less_edge less_edge;
  typedef typename Ctr::Edge_set Edge_set;
#ifndef CGAL_CFG_USING_BASE_MEMBER_BUG_2
  using Ctr::geom_traits;
  using Ctr::number_of_vertices;
  using Ctr::finite_faces_begin;
  using Ctr::finite_faces_end;
  using Ctr::dimension;
  using Ctr::cw;
  using Ctr::ccw;
  using Ctr::infinite_vertex;
  using Ctr::side_of_oriented_circle;
  using Ctr::is_infinite;
  using Ctr::collinear_between;
  using Ctr::are_there_incident_constraints;
  using Ctr::make_hole;
  using Ctr::insert_constraint;
  using Ctr::locate;
  using Ctr::test_dim_down;
  using Ctr::fill_hole_delaunay;
  using Ctr::update_constraints;
  using Ctr::delete_vertex;
  using Ctr::push_back;
#endif
  typedef typename Geom_traits::Point_2  Point;
  Constrained_Delaunay_triangulation_2(const Geom_traits& gt=Geom_traits())
    : Ctr(gt) { }
  Constrained_Delaunay_triangulation_2(const CDt& cdt)
    : Ctr(cdt) {}
  Constrained_Delaunay_triangulation_2(List_constraints& lc,
    : Ctr(gt)
      typename List_constraints::iterator itc = lc.begin();
      for( ; itc != lc.end(); ++itc) {
	insert((*itc).first, (*itc).second);
      CGAL_triangulation_postcondition( is_valid() );
  template<class InputIterator>
  Constrained_Delaunay_triangulation_2(InputIterator it,
				       InputIterator last,
				       const Geom_traits& gt=Geom_traits() )
    : Ctr(gt)
      for ( ; it != last; it++) {
      	insert((*it).first, (*it).second);
  virtual ~Constrained_Delaunay_triangulation_2() {}
  // FLIPS
  bool is_flipable(Face_handle f, int i, bool perturb = true) const;
  void flip(Face_handle& f, int i);
  void flip_around(Vertex_handle va);
  void flip_around(List_vertices & new_vertices);
  void propagating_flip(Face_handle& f,int i);
  void propagating_flip(List_edges & edges);
  // CONFLICTS
  bool test_conflict(Face_handle fh, const Point& p) const; //deprecated
  bool test_conflict(const Point& p, Face_handle fh) const;
  void find_conflicts(const Point& p, std::list<Edge>& le,  //deprecated
		      Face_handle hint= Face_handle()) const;
  //  //template member functions, declared and defined at the end
  // template <class OutputItFaces, class OutputItBoundaryEdges>
  // std::pair<OutputItFaces,OutputItBoundaryEdges>
  // get_conflicts_and_boundary(const Point  &p,
  // 		                OutputItFaces fit,
  // 		                OutputItBoundaryEdges eit,
  // 		                Face_handle start) const;
  // template <class OutputItFaces>
  // OutputItFaces
  // get_conflicts (const Point  &p,
  // 		    Face_handle start ) const;
  // template <class OutputItBoundaryEdges>
  // get_boundary_of_conflicts(const Point  &p,
  // INSERTION-REMOVAL
  Vertex_handle insert(const Point & a, Face_handle start = Face_handle());
  Vertex_handle insert(const Point& p,
		       Locate_type lt,
		       Face_handle loc, int li );
  Vertex_handle push_back(const Point& a);
//   template < class InputIterator >
//   std::ptrdiff_t insert(InputIterator first, InputIterator last);
  void remove(Vertex_handle v);
  void remove_incident_constraints(Vertex_handle v);
  void remove_constrained_edge(Face_handle f, int i);
//  OutputItFaces
//  remove_constrained_edge(Face_handle f, int i, OutputItFaces out)
  //for backward compatibility
  void insert(Point a, Point b) { insert_constraint(a, b);}
  void insert(Vertex_handle va, Vertex_handle  vb) {insert_constraint(va,vb);}
  void remove_constraint(Face_handle f, int i){remove_constrained_edge(f,i);}
  // CHECK
  bool is_valid(bool verbose = false, int level = 0) const;
protected:
  virtual Vertex_handle virtual_insert(const Point & a,
  virtual Vertex_handle virtual_insert(const Point& a,
				       Locate_type lt,
				       Face_handle loc,
				       int li );
//Vertex_handle special_insert_in_edge(const Point & a, Face_handle f, int i);
  void remove_2D(Vertex_handle v );
  virtual void triangulate_hole(List_faces& intersected_faces,
				List_edges& conflict_boundary_ab,
				List_edges& conflict_boundary_ba);
public:
  // MESHING
  // suppressed meshing functions from here
public:
#if defined(_MSC_VER)
  std::ptrdiff_t insert(InputIterator first, InputIterator last, int i = 0)
#else
#endif
      size_type n = number_of_vertices();
      std::vector<Point> points (first, last);
      spatial_sort (points.begin(), points.end(), geom_traits());
      Face_handle f;
      for (typename std::vector<Point>::const_iterator p = points.begin(), end = points.end();
              p != end; ++p)
          f = insert (*p, f)->face();
      return number_of_vertices() - n;
			     OutputItFaces fit,
			     Face_handle start = Face_handle()) const {
    CGAL_triangulation_precondition( dimension() == 2);
    int li;
    Locate_type lt;
    Face_handle fh = locate(p,lt,li, start);
    switch(lt) {
    case Ctr::OUTSIDE_AFFINE_HULL:
    case Ctr::VERTEX:
      return std::make_pair(fit,eit);
    case Ctr::FACE:
    case Ctr::EDGE:
    case Ctr::OUTSIDE_CONVEX_HULL:
      *fit++ = fh; //put fh in OutputItFaces
	pit = std::make_pair(fit,eit);
      pit = propagate_conflicts(p,fh,0,pit);
      pit = propagate_conflicts(p,fh,1,pit);
      pit = propagate_conflicts(p,fh,2,pit);
      return pit;
    CGAL_triangulation_assertion(false);
  OutputItFaces
		 OutputItFaces fit,
		 Face_handle start= Face_handle()) const {
    std::pair<OutputItFaces,Emptyset_iterator> pp =
      get_conflicts_and_boundary(p,fit,Emptyset_iterator(),start);
    return pp.first;
    std::pair<Emptyset_iterator, OutputItBoundaryEdges> pp =
      get_conflicts_and_boundary(p,Emptyset_iterator(),eit,start);
    return pp.second;
public:
// made  public for the need of Mesh_2
// but not documented
 propagate_conflicts (const Point  &p,
		      Face_handle fh,
		      int i,
		      std::pair<OutputItFaces,OutputItBoundaryEdges>  pit)  const {
   Face_handle fn = fh->neighbor(i);
   if ( fh->is_constrained(i) || ! test_conflict(p,fn)) {
     *(pit.second)++ = Edge(fn, fn->index(fh));
   } else {
     *(pit.first)++ = fn;
     int j = fn->index(fh);
     pit = propagate_conflicts(p,fn,ccw(j),pit);
     pit = propagate_conflicts(p,fn,cw(j), pit);
   return pit;
public:
 OutputItFaces
 propagating_flip(List_edges & edges,
		  OutputItFaces out = Emptyset_iterator()) {
  // makes the triangulation Delaunay by flipping
  // List edges contains an initial list of edges to be flipped
  // Precondition : the output triangulation is Delaunay if the list
  // edges contains all edges of the input triangulation that need to be
  // flipped (plus possibly others)
  int i, ii, indf, indn;
  Face_handle ni, f,ff;
  Edge ei,eni;
  typename Ctr::Edge_set edge_set;
  Edge e[4];
  typename List_edges::iterator itedge=edges.begin();
  // initialization of the set of edges to be flip
  while (itedge != edges.end()) {
    f=(*itedge).first;
    i=(*itedge).second;
    if (is_flipable(f,i)) {
      eni=Edge(f->neighbor(i),this->mirror_index(f,i));
      if (less_edge(*itedge,eni)) edge_set.insert(*itedge);
      else edge_set.insert(eni);
    ++itedge;
  // flip edges and updates the set of edges to be flipped
  while (!(edge_set.empty())) {
    f=(*(edge_set.begin())).first;
    indf=(*(edge_set.begin())).second;
    // erase from edge_set the 4 edges of the wing of the edge to be
    // flipped (edge_set.begin) , i.e. the edges of the faces f and
    // f->neighbor(indf) that are distinct from the edge to be flipped
    ni = f->neighbor(indf);
    indn=this->mirror_index(f,indf);
    ei= Edge(f,indf);
    edge_set.erase(ei);
    e[0]= Edge(f,cw(indf));
    e[1]= Edge(f,ccw(indf));
    e[2]= Edge(ni,cw(indn));
    e[3]= Edge(ni,ccw(indn));
    for(i=0;i<4;i++) {
      ff=e[i].first;
      ii=e[i].second;
      eni=Edge(ff->neighbor(ii),this->mirror_index(ff,ii));
      if (less_edge(e[i],eni)) {edge_set.erase(e[i]);}
      else { edge_set.erase(eni);}
    // here is the flip
    *out++ = f;
    *out++ = f->neighbor(indf);
    flip(f, indf);
    //insert in edge_set the 4 edges of the wing of the edge that
    //have been flipped
    e[0]= Edge(f,indf);
    e[1]= Edge(f,cw(indf));
    e[2]= Edge(ni,indn);
    e[3]= Edge(ni,cw(indn));
    for(i=0;i<4;i++) {
      ff=e[i].first;
      ii=e[i].second;
      if (is_flipable(ff,ii)) {
	  edge_set.insert(e[i]);}
	else {
	  edge_set.insert(eni);}
  return out;
 OutputItFaces
 remove_constrained_edge(Face_handle f, int i, OutputItFaces out) {
  Ctr::remove_constrained_edge(f,i);
  if(dimension() == 2) {
    List_edges le;
    le.push_back(Edge(f,i));
    propagating_flip(le,out);
  return out;
  inline
  Point dual (Face_handle f) const
    CGAL_triangulation_precondition(this->_tds.is_face(f));
    CGAL_triangulation_precondition (this->dimension()==2);
    return this->circumcenter(f);
template < class Gt, class Tds, class Itag >
bool
Constrained_Delaunay_triangulation_2<Gt,Tds,Itag>::
is_flipable(Face_handle f, int i, bool perturb) const
  // determines if edge (f,i) can be flipped
  Face_handle ni = f->neighbor(i);
  if (is_infinite(f) || is_infinite(ni)) return false;
  if (f->is_constrained(i)) return false;
  return (side_of_oriented_circle(ni, f->vertex(i)->point(), perturb)
                                        == ON_POSITIVE_SIDE);
void
flip (Face_handle& f, int i)
  Face_handle g = f->neighbor(i);
  int j = this->mirror_index(f,i);
  // save wings neighbors to be able to restore contraint status
  Face_handle f1 = f->neighbor(cw(i));
  int i1 = this->mirror_index(f,cw(i));
  Face_handle f2 = f->neighbor(ccw(i));
  int i2 = this->mirror_index(f,ccw(i));
  Face_handle f3 = g->neighbor(cw(j));
  int i3 = this->mirror_index(g,cw(j));
  Face_handle f4 = g->neighbor(ccw(j));
  int i4 = this->mirror_index(g,ccw(j));
  // The following precondition prevents the test suit
  // of triangulation to work on constrained Delaunay triangulation
  //CGAL_triangulation_precondition(is_flipable(f,i));
  this->_tds.flip(f, i);
  // restore constraint status
  f->set_constraint(f->index(g), false);
  g->set_constraint(g->index(f), false);
  f1->neighbor(i1)->set_constraint(this->mirror_index(f1,i1),
				   f1->is_constrained(i1));
  f2->neighbor(i2)->set_constraint(this->mirror_index(f2,i2),
				   f2->is_constrained(i2));
  f3->neighbor(i3)->set_constraint(this->mirror_index(f3,i3),
				   f3->is_constrained(i3));
  f4->neighbor(i4)->set_constraint(this->mirror_index(f4,i4),
				   f4->is_constrained(i4));
  return;
void
  // makes the triangles incident to vertex va Delaunay using flips
  if (dimension() <= 1) return;
  Face_handle f=va->face();
  Face_handle next;
  Face_handle start(f);
  int i;
  do {
    i = f->index(va); // FRAGILE : DIM 1
    next = f->neighbor(ccw(i));  // turns ccw around a
    propagating_flip(f,i);
    f=next;
  } while(next != start);
void
flip_around(List_vertices& new_vertices)
  typename List_vertices::iterator itv=new_vertices.begin();
  for( ; itv != new_vertices.end(); itv++) {
    flip_around(*itv);
  return;
void
// similar to the corresponding function in Delaunay_triangulation_2.h
  if (!is_flipable(f,i)) return;
  flip(f, i); // flip for constrained triangulations
  i = ni->index(f->vertex(i));
  propagating_flip(ni,i);
 void
 propagating_flip(List_edges & edges) {
    propagating_flip(edges,Emptyset_iterator());
inline bool
  // true if point P lies inside the circle circumscribing face fh
  // return true  if P is inside the circumcircle of fh
  // if fh is infinite, return true when p is in the positive
  // halfspace or on the boundary and in the  finite edge of fh
  Oriented_side os = side_of_oriented_circle(fh,p,true);
  if (os == ON_POSITIVE_SIDE) return true;
  if (os == ON_ORIENTED_BOUNDARY && is_infinite(fh)) {
    int i = fh->index(infinite_vertex());
    return collinear_between(fh->vertex(cw(i))->point(), p,
			     fh->vertex(ccw(i))->point() );
  return false;
inline bool
  return test_conflict(p,fh);
void
find_conflicts(const Point& p, std::list<Edge>& le, Face_handle hint) const
  // sets in le the counterclocwise list of the edges of the boundary of the
  // union of the faces in conflict with p
  // an edge is represented by the incident face that is not in conflict with p
  get_boundary_of_conflicts(p, std::back_inserter(le), hint);
inline
typename Constrained_Delaunay_triangulation_2<Gt,Tds,Itag>::Vertex_handle
virtual_insert(const Point & a, Face_handle start)
  // virtual version of the insertion
  return insert(a,start);
inline
	       Locate_type lt,
	       Face_handle loc,
	       int li )
// virtual version of insert
  return insert(a,lt,loc,li);
inline
 // inserts a in the triangulation
// constrained edges are updated
// Delaunay property is restored
  Vertex_handle va= Ctr::insert(a, start);
  flip_around(va);
  return va;
insert(const Point& a, Locate_type lt, Face_handle loc, int li)
// insert a point p, whose localisation is known (lt, f, i)
  Vertex_handle va= Ctr::insert(a,lt,loc,li);
  flip_around(va);
  return va;
inline
push_back(const Point &p)
  return insert(p);
void
  List_edges new_edges;
  Ctr::triangulate_hole(intersected_faces,
		       conflict_boundary_ba,
		       new_edges);
  propagating_flip(new_edges);
  return;
inline void
  // remove a vertex and updates the constrained edges of the new faces
  // precondition : there is no incident constraints
  CGAL_triangulation_precondition( v != Vertex_handle() );
  CGAL_triangulation_precondition( ! is_infinite(v));
  CGAL_triangulation_precondition( ! are_there_incident_constraints(v));
  if  (dimension() <= 1)    Ctr::remove(v);
  else  remove_2D(v);
  return;
// template < class Gt, class Tds, class Itag >
// typename
// Constrained_Delaunay_triangulation_2<Gt,Tds,Itag>::Vertex_handle
// special_insert_in_edge(const Point & a, Face_handle f, int i)
//   // insert  point p in edge(f,i)
//   // bypass the precondition for point a to be in edge(f,i)
//   // update constrained status
//   // this member fonction is not robust with exact predicates
//   // and approximate construction. Should be removed
//   Vertex_handle vh=Ctr::special_insert_in_edge(a,f,i);
//   flip_around(vh);
//   return vh;
void
remove_2D(Vertex_handle v)
 if (test_dim_down(v)) {  this->_tds.remove_dim_down(v);  }
  else {
     std::list<Edge> hole;
    make_hole(v, hole);
    std::list<Edge> shell=hole; //because hole will be emptied by fill_hole
    fill_hole_delaunay(hole);
    update_constraints(shell);
    delete_vertex(v);
  return;
void
   List_edges iconstraints;
   if (are_there_incident_constraints(v,
				      std::back_inserter(iconstraints))) {
     Ctr::remove_incident_constraints(v);
     if (dimension()==2) propagating_flip(iconstraints);
   return;
void
  remove_constrained_edge(f,i,Emptyset_iterator());
  return;
bool
is_valid(bool verbose, int level) const
  bool result = Ctr::is_valid(verbose, level);
  CGAL_triangulation_assertion( result );
    Finite_faces_iterator fit= finite_faces_begin();
    for (; fit != finite_faces_end(); fit++) {
      for(int i=0;i<3;i++) {
	result = result && !is_flipable(fit,i, false);
    return result;
} //namespace CGAL
#endif // CGAL_CONSTRAINED_DELAUNAY_TRIANGULATION_2_H
