- To:
- Subject: Re: [cgal-discuss] How can I insert the point with infor into Triangulation?
- Date: Fri, 11 Feb 2011 10:24:51 +0100
xianhai meng wrote:
thanks, it works well But I have another problem that when I inserted almost 440 thousand points intoread this thread:
the Delaunay_triangulation_3 the process is very slow with the speed of sixty
points per second.
There must be some problem I don't konw.
Btw, I am programming under VS2008 in Window 7.
https://lists-sop.inria.fr/sympa/arc/cgal-discuss/2010-01/msg00003.html
S.
- [cgal-discuss] How can I insert the point with infor into Triangulation?, not3not4, 02/10/2011
- Re: [cgal-discuss] How can I insert the point with infor into Triangulation?, Sebastien Loriot (GeometryFactory), 02/10/2011
- Re: Re: [cgal-discuss] How can I insert the point with infor into Triangulation?, xianhai meng, 02/11/2011
- Re: [cgal-discuss] How can I insert the point with infor into Triangulation?, Sebastien Loriot (GeometryFactory), 02/11/2011
