- To:
- Subject: [cgal-discuss] Re: Screen easely Cells, Facets, Edges, AlphaShape3D Weighted
- Date: Fri, 11 Feb 2011 02:31:01 -0800 (PST)
Thank you it works ! ;)
But there are some issues in the results.
I have got some big edge even with a small Alpha (=0.0)
I take the same weight for each point for example.
When I process the AlphaShape 0.0 normaly the maximum distance is
2*ray_alpha_shape + 2*weight so in my example i put 1.8 for weight at each
point and the result is that I've got edge mesurement at more than 10 !
How it is possible, do I understand bad ?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Screen-easely-Cells-Facets-Edges-AlphaShape3D-Weighted-tp3297041p3301070.html
- Re: [cgal-discuss] Screen easely Cells, Facets, Edges, AlphaShape3D Weighted, (continued)
- Re: [cgal-discuss] Screen easely Cells, Facets, Edges, AlphaShape3D Weighted, Sebastien Loriot (GeometryFactory), 02/09/2011
- [cgal-discuss] Re: Screen easely Cells, Facets, Edges, AlphaShape3D Weighted, MrVH, 02/09/2011
- Re: [cgal-discuss] Re: Screen easely Cells, Facets, Edges, AlphaShape3D Weighted, Sebastien Loriot (GeometryFactory), 02/09/2011
- [cgal-discuss] Re: Screen easely Cells, Facets, Edges, AlphaShape3D Weighted, MrVH, 02/10/2011
- Re: [cgal-discuss] Re: Screen easely Cells, Facets, Edges, AlphaShape3D Weighted, Sebastien Loriot (GeometryFactory), 02/10/2011
- [cgal-discuss] Re: Screen easely Cells, Facets, Edges, AlphaShape3D Weighted, MrVH, 02/11/2011
- Re: [cgal-discuss] Re: Screen easely Cells, Facets, Edges, AlphaShape3D Weighted, Sebastien Loriot (GeometryFactory), 02/11/2011
- [cgal-discuss] Re: Screen easely Cells, Facets, Edges, AlphaShape3D Weighted, MrVH, 02/12/2011
- Re: [cgal-discuss] Re: Screen easely Cells, Facets, Edges, AlphaShape3D Weighted, Sebastien Loriot (GeometryFactory), 02/12/2011
- [cgal-discuss] Re: Screen easely Cells, Facets, Edges, AlphaShape3D Weighted, MrVH, 02/14/2011
- Re: [cgal-discuss] Re: Screen easely Cells, Facets, Edges, AlphaShape3D Weighted, Sebastien Loriot (GeometryFactory), 02/16/2011
