- To:
- Subject: Re: [cgal-discuss] Re: CMake Problem
- Date: Mon, 14 Feb 2011 10:52:26 +0100
Le lundi 14 février 2011 06:13:32, PK Jao a écrit :
> Hi all
> I just changed the variable _boost_COMPILER in FindBoost.cmake to "-vc100"
> and the problem is solved.
> Is there any one using Borland compiler? I am confused now how to use CGAL
> in CodeGear.
The Borland compiler is not supported by the CGAL project, because not any
CGAL developer uses it, and this that compiler is not tested.
I am afraid you are on your own.
Laurent Rineau, PhD
- [cgal-discuss] CMake Problem, PK Jao, 02/13/2011
- [cgal-discuss] Re: CMake Problem, PK Jao, 02/14/2011
- Re: [cgal-discuss] Re: CMake Problem, Laurent Rineau (GeometryFactory), 02/14/2011
- Re:[cgal-discuss] Re: CMake Problem, 碰碰, 02/14/2011
