cgal-discuss - Re: [cgal-discuss] Problem + ubuntu 10.4 + Eclipse+ GMP + Exact_predicates_inexact_constructions_kernel.h
  • To:
  • Subject: Re: [cgal-discuss] Problem + ubuntu 10.4 + Eclipse+ GMP + Exact_predicates_inexact_constructions_kernel.h
  • Date: Wed, 16 Feb 2011 13:24:44 +0100
Le mercredi 16 février 2011 13:07:05, tochaf a écrit :
> Hy
> I had installed libcgal 3.5.1-1 from synaptic on my ubuntu 10.4.
> Now, i able to use some functions of CGAL, as instance of:
> #include <CGAL/Constrained_Delaunay_triangulation_2.h>
> #include <CGAL/Triangulation_hierarchy_2.h>
> #include <CGAL/Constrained_triangulation_plus_2.h>
> However, when i try to use:
> #include <CGAL/Exact_predicates_inexact_constructions_kernel.h>
> I lead to:
> /usr/include/boost/operators.hpp:129: error: template instantiation depth
> exceeds maximum of 50 (use -ftemplate-depth-NN to increase the maximum)
> instantiating ‘struct
> boost::equality_comparable2<CGAL::Quotient<CGAL::MP_Float>, double,
> boost::detail::empty_base<CGAL::Quotient<CGAL::MP_Float> > >’
> /usr/include/boost/operators.hpp:129: instantiated from
> ‘boost::less_than_comparable2<CGAL::Quotient<CGAL::MP_Float>, double,
> boost::detail::empty_base<CGAL::Quotient<CGAL::MP_Float> > > >’
> /usr/include/boost/operators.hpp:409: instantiated from
> ‘boost::totally_ordered2<CGAL::Quotient<CGAL::MP_Float>, double,
> and so on, a lot of errors.
> I use gcc as "compilator" in my eclipse projects.
> Thus, is it a gmp issue? Why
> Exact_predicates_inexact_constructions_kernel.h "doesnt work"?
This is not a GMP issue.
It seems your Eclipse project uses the compilation flag
"-ftemplate-depth-50".
Modify the Eclipse project to remove it, or use "-ftemplate-depth-1000"
instead. You also absolutely need the compilation flag "-frounding-math" if
not present, and absolutelu NOT "-ffast-math" (remove it or use
-fno-fast-math
instead).
Probably the CGAL::Exact_predicates_inexact_constructions_kernel needs more
than 50 levels of templates. I am not surprised because this kernel falls
back
to an exact arithmetic using CGAL::Quotient<CGAL::MP_Float>, and that number
types uses the Boost.operators library (from www.boost.org), that needs a lot
of templates levels.
Note that it seems your CGAL installation is configured not to use GMP, but
CGAL::MP_Float instead for exact arithmetic. It would be better to configure
CGAL with GMP, because GMP is faster than the internal class CGAL::MP_Float.
You should add "-DCGAL_USE_GMP" and "-DCGAL_USE_MPFR" to your compilation
flags. Those flags you be in /usr/include/CGAL/compiler_config.h, and I
wonder
why they are not defined...
Laurent Rineau, PhD
