Re: [cgal-discuss] Problem + ubuntu 10.4 + Eclipse+ GMP + Exact_predicates_inexact_constructions_kernel.h
- To:
- Subject: Re: [cgal-discuss] Problem + ubuntu 10.4 + Eclipse+ GMP + Exact_predicates_inexact_constructions_kernel.h
- Date: Wed, 16 Feb 2011 19:53:57 +0100
Le mercredi 16 février 2011 19:49:23, Antonio Ferraz a écrit :
> Salut
> Thanks for the reply.
> It's sounds good, however ( i think) I have some Cmake problems
> I added "-ftemplate-depth-1000" but unfortunately still the same error.
> When i look to the CMakeChache "-ftemplate-depth-50" stills there, so far,
> I use both
> "-ftemplate-depth-50" and "-ftemplate-depth-1000". I do not know how to
> remove "-ftemplate-depth-50" from the compilation, despite the few hours
> looking for a answer.
> I use also others libraries in the same project (ITK, OTB, LIDARFORMAT
> etc), and i dont know if the problem can rely on that. I had changed also
> , for example, "-ftemplate-depth-50" to "-ftemplate-depth-1000" on ITK
> CMakeList but nothing, impossible to kill "-ftemplate-depth-50"
If I remember well, ITK is the culprit.
> Concerning the other question, I really have in
> "/usr/include/CGAL/compiler_config.h" "CGAL_USE_GMP 1" and "
> CGAL_USE_MPFR 1" defined.
> I should have "-DCGAL_USE_GMP" and "-DCGAL_USE_MPFR" instead, as you said
> in the last reply?
No. That is fine. I wonder why your compiler showed an error with MP_Float if
CGAL_USE_GMP is defined.
Laurent Rineau, PhD
- [cgal-discuss] Problem + ubuntu 10.4 + Eclipse+ GMP + Exact_predicates_inexact_constructions_kernel.h, tochaf, 02/16/2011
- Re: [cgal-discuss] Problem + ubuntu 10.4 + Eclipse+ GMP + Exact_predicates_inexact_constructions_kernel.h, Laurent Rineau (GeometryFactory), 02/16/2011
- Re: [cgal-discuss] Problem + ubuntu 10.4 + Eclipse+ GMP + Exact_predicates_inexact_constructions_kernel.h, Antonio Ferraz, 02/16/2011
