Re: [cgal-discuss] Re: Assertion violation when converting polyhedron to Nef_polyhedron
- To:
- Subject: Re: [cgal-discuss] Re: Assertion violation when converting polyhedron to Nef_polyhedron
- Date: Thu, 17 Feb 2011 16:11:49 +0100
johnzjq wrote:
I did some other tests and find the cause is probably the precision of the
vertices. If I translate the model from the world coordinate system to the local
cooridinate system, most of the models could pass the TEST described above.
However, if the precision of the model is reduced, for example, from 1e-6 to
1e-4, Minkowski Sum will fail on my data set.
I think I get lost.
is the title of the thread still appropriate?
You seems to have encountered a lot of problems.
Could you please provide again the minimal examples and data
with the list of command lines that failed and those that are OK.
That way it will be easier for me.
Sorry for the duplicate work.
S.
- [cgal-discuss] Re: Assertion violation when converting polyhedron to Nef_polyhedron, johnzjq, 02/09/2011
- [cgal-discuss] Re: Assertion violation when converting polyhedron to Nef_polyhedron, johnzjq, 02/17/2011
- Re: [cgal-discuss] Re: Assertion violation when converting polyhedron to Nef_polyhedron, Sebastien Loriot (GeometryFactory), 02/17/2011
- [cgal-discuss] Re: Assertion violation when converting polyhedron to Nef_polyhedron, johnzjq, 02/22/2011
