[cgal-discuss] Re: Assertion violation when converting polyhedron to Nef_polyhedron
- To:
- Subject: [cgal-discuss] Re: Assertion violation when converting polyhedron to Nef_polyhedron
- Date: Thu, 17 Feb 2011 05:20:08 -0800 (PST)
I did some other tests and find the cause is probably the precision of the
vertices.
If I translate the model from the world coordinate system to the local
cooridinate system, most of the models could pass the TEST described above.
However, if the precision of the model is reduced, for example, from 1e-6 to
1e-4, Minkowski Sum will fail on my data set.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Assertion-violation-when-converting-polyhedron-to-Nef-polyhedron-tp3220004p3310746.html
- [cgal-discuss] Re: Assertion violation when converting polyhedron to Nef_polyhedron, johnzjq, 02/09/2011
- [cgal-discuss] Re: Assertion violation when converting polyhedron to Nef_polyhedron, johnzjq, 02/17/2011
- Re: [cgal-discuss] Re: Assertion violation when converting polyhedron to Nef_polyhedron, Sebastien Loriot (GeometryFactory), 02/17/2011
- [cgal-discuss] Re: Assertion violation when converting polyhedron to Nef_polyhedron, johnzjq, 02/22/2011
